Rear floating remote from Kioti for Bobcat CT 235 - It Works!!!!
   / Rear floating remote from Kioti for Bobcat CT 235 - It Works!!!! #1
powerscol
SW Colorado
CT 235
For those that want a second rear remote with FLOAT, Kioti has a valve that fits our tractors. I installed it on my CT 235, but I believe it will fit others that have this same frame.
The Kioti second float valve kit Part #322027 fits perfectly. I actually had the dealer install as I was getting in over my head without the proper tools. It does have the float detent past the D setting, but does not have detents like the first valve installed where you can hold in the A or B position to provide continuous flow to a device like a log splitter.. This will work perfectly for my sickle mower.
Two thing to check when you order you kit from Kioti is one - make sure the valve in the kit says (part number 008274) and is labeled valve-double acting FLOAT, Second make sure there are 4 nylon washers in the kit to space out the lever arm. If not they are Bobcat part numbers 6696901 (4 needed). Otherwise you can cut down the existing wide nylon spacer if you have the single remote kit installed already. This Kioti kit will not fit in the first position as the tubes to the back will not line up. It must be installed as the second valve.
I have not used it yet, but my Bobcat mechanic indicated it was a perfect fit.
   / Rear floating remote from Kioti for Bobcat CT 235 - It Works!!!! #2
Nice to finally have this confirmed. :thumbsup: Now just hope that Kioti does not discontinue these items. :eek:
The last dealer I talked with seems to think they will be around a while, but folks must check that the kit they get has the correct valve. Even the Kioti service rep on their web page where owners can ask questions, did not know.
I had the lever arm threaded so I can raise it a bit for better operation. When I get to it I'll post pictures.
   / Rear floating remote from Kioti for Bobcat CT 235 - It Works!!!! #4
I'm late to this party. Are these Kioti OEM valves that are available new, or are they some last remaining leftovers someone had in a warehouse?
Stock Kioti OEM second rear remote kit #322027 that fits their CK 20 thru CK35 units.
2004 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A57880)
2004 FREIGHTLINER...
2014 JCB 930 (A53317)
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
garbage truck 2017 (A56858)
garbage truck 2017...
2008 Dodge Ram 1500 Single Cab Pickup Truck (A55973)
2008 Dodge Ram...
2014 Chevrolet Impala LT Sedan (A56859)
2014 Chevrolet...
