Rear flat
/ Rear flat #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
Well only had my Ford 3000 for a week and already have a rear flat. Slow leak as it takes 24 hours for it to go completly flat. No way I am strong enough to get the tire in the back of my pickup and never fixed a tire before. Am pretty sure it has a tube so what's the best course of action towards getting it fixed?
/ Rear flat #2
Contact your dealer..or any tractor dealer, and ask them if there is a tire service company who can come to your place.
Another option is to contact one of those companies that change truck tires on the road.
Ain't gonna be cheap though...
/ Rear flat #3
Very good advice. I live in an area with lots of timber being harvested. Those rolling tire service trucks are in my area several times a week. I've had flats repaired many times where my tractor is sitting. Cheaper than me hauling it 10 miles and busting a gut trying to load and unload.
They make the repair on the tractor too. I've had rears (16.9x30's and 16.9x28's)repaired from $110 - $135. May be higher now with the price of fuel being way up.
/ Rear flat
Thanks,
Just went out an squirted the whole tire down with soap suds, only place I saw bubbles was whear the valve stem comes through the rim. Close inspection didn't reviel any nails, screws or other punctures so my guess would be the tube is leaking inside the tire someplace /forums/images/graemlins/confused.gif
/ Rear flat
Not sure if Slime would do anything, thinking it might be on the inside toward the center of the rim and slime wouldn't get to the leak.
It's worth $100.00 + to not have to deal with it...
/ Rear flat #7
I had been troubled with an intermittant leak in a front R4 on my Kubota. This was a tubeless tire. I have been having back problems so call a local tire service company who came out, pulled the tire and rim, found some "flash" on the bead area of the tire. Cleaned it all up, inflated, remounted all for less than $50. A bargain in my money. I inquired about their being able to service the loaded rear tires and was told "no problem". I do not remember the projected price but remember it as being reasonable.
I do not plan to fight any tractor flats by myself anymore.
Vernon
/ Rear flat
Just called Danny's Tire Service on a recomendation from a dealer. He is comming out Monday, $20.00 service call and $50.00 to fix it. I figure it's a bargan concidering the options /forums/images/graemlins/smirk.gif
/ Rear flat #9
I had very slow leaks in both of my loaded rear tires. After putting up with them for over a year I called out the mobile service and they drained the tires, put in new tubes and reloaded the tires for under $100. I provided the new tubes, they provided 10 gallons of CaCl.
/ Rear flat #10
I had to do the same thing a few years back, stem broke on my Ford 2N was winter, and the wife was in the hospital and i was working afternoon shift. called the tire place (they do all the big tractor and trucks around here) they sent a guy out that same afternoon, while i was at work, repaced the upper part of the valve stem, refilled thew tire with calcium and called me the next day with the price $85 . they sure helped me out during a rough few days, so they get all my business now. /forums/images/graemlins/smile.gif
/ Rear flat #11
That's a good price anywhere in the country. If it is just a tube broken, he can do it with the wheel on the tractor - the Co-op I used to work for did them all the time that way if they could, will save alot of time and grunt work.
/ Rear flat #12
Bob.. I've got a sugestion for you. Have a roll of duct tape on hand when the guy gets there. If the inside of the rim is rusty and has pierced the tube.. new tube or patch will do the same inshort order.
Real fix is to break down the rim.. and sandblast or wire wheel till smooth, then paint with a rusty metal primer/sealing paint.. "quick old iron' way to fix it is to roll a few layers of duct tape in the rim... Don't laugh.. lots of old tractors rolling around like this.. or with the old tube cut up and used as a boot against the rusty rim.. etc.
Soundguy
/ Rear flat
Great tip on the duct tape, thanks.
Danny showed up yesterday and we discovered the previous owner had put on a new tire without replacing the tube or cleaning up the rim. The tube not only had several patches it was wasted from rust scale on the rim. At my request Danny pulled the tire completely off the rim and left me with it. This gave me time to clean it up and go get a new tube.
Spent about an hour with my angle grinder/wire brush cleaning up the inside of the rim, sprayed it with Extend, (some rust converter I had laying around). After the Extend was dry I painted the inside of the rim with Rustolieum(sp) and must say except for the many rust pits it doesn't look or feel too bad. There are a couple of places pitted pretty bad and think I will use the duct tape trick just to be sure I don't have another problem down the road.
He is coming back today to put it back together, going to end up costing me $90.00 for the two trips plus the new tube but this time it is as right as I can make it. I'll never understand why some people will spend the money for a new tire and not replace a $30.00 tube.
/ Rear flat #14
I've pulled fronts of fmy N tractors that use 4$ tubes.. and found patches /forums/images/graemlins/shocked.gif
I did as you did.. wire wheeled the rim.. hit it with a rust stopper primer, then painted it liberally ( many coats ) with an appliance epoxy enamil i had laying around. Like yours.. came out smooth, with some evident pitting.
I put the tube and tire on and it has been that way for 2ys now. If the pitting bothers you, you can use just about any type of sndible filler then repaint for a smooth finish.. however.. once you get the prickly stuff out.. the tube is much happier, even if a few pits remain. On my worst rim, also a front.. there was alot of welding and brazing .. whole lotta pitting.. I use the old tube as a boot.. just cut the sides and middle out... that's holding air now as well..
Sounds like yours will be fine. ( Learned the duct tape trick from a tire guy (among others ) that services alot of farms... he took a roll out on farm calls.. said sometimes the farmer didn't have time to 'fix' the rim.. so they did the duct tape thingy as a stopgap measure.. )
Soundguy
/ Rear flat #15
20051014
Some of you guys are lucky, or perhaps closer to the dealer than I. My best quote for simple work at my location was $160+ for just coming out and swapping tires from one side to the other (to gain width), most of which was travel, etc.
Noted that Charlois, who is also from Va, quoted some higher prices.
The tires on my NH are indeed heavy even with no fluid--about 200-250# each /forums/images/graemlins/shocked.gif
J
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2010 Ford Mustang Sedan (A61569)
2010 Ford Mustang...
2011 JOHN DEERE 75D EXCAVATOR (A62129)
2011 JOHN DEERE...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
RoadTec RP190 (A61307)
2013 KENWORTH T800 SLEEPER (A59906)
2013 KENWORTH T800...
