JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,986
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
I mow 3-4 acre behind my pole barn with a RFM. It is always to wet to mow until around this time of year-so the first mowing is done with a rotary cutter. After that, I have no problem mowing every 2-3 weeks until fall with the RFM. It handles 6-8" grass as fast as the field allows me to go.
Will
As others said, it depends on a lot of things. One thing about finish mowers you need to know is that they do not work well in tall or heavy grass. I had grass that grew very high -- 18" or more -- in a month's time. NOT good for a finish mower. Since I have a a few acres that I can only mow once a month I found the finish mower was simply the wrong tool. It was a good solid 6ft Landpride bought new. Traded it off and found that a sharp bladed bush hog will leave a cleaner job than a finish mower under the circumstances just described. I also went thru some belts on the finish mower. Guy who uses my old finish mower says that as long as he cuts often and does not let the grass get more than ankle deep the finish mower does a great job.
Unless you can mow often (About like you would the lawn around a home) then the finish mower is not the right tool.
