Rear Finish Mower Rear Finish Mower Sizing. Want 72" on MF - GC1720
   / Rear Finish Mower Sizing. Want 72" on MF - GC1720 #1
ryan86754
Massey GC1720
New to the site. So much great info on here.
Looking to purchase a Massey GC1720 SCUT. Would like to put a 72" RFM behind it, but the PTO HP for the MF 1720 is only 19.6 and most of the 72" RFMs that I find require 20hp. Does anyone on here run a 72" RFM on a SCUT? If so, what is your PTO HP?
Thanks for the help.
   / Rear Finish Mower Sizing. Want 72" on MF - GC1720 #2
2 concerns-I think you would any on power if you tried to mow any more than 2 inches of grass, and I think the weight of a 6' finish would push a SCUT around quite a bit. I used a 5' finish mower on. 26hp Kubota B2620 it was a perfect fit.
Will
Thanks Will. I generally mow 1-2 times per week, so the height won't be an issue. Do you think the weight of the FEL would help in being pushed around?
I'm really looking for ways to reduce time on mowing the yard.
Thanks.
   / Rear Finish Mower Sizing. Want 72" on MF - GC1720 #4
I have an LS mt125 (which is similar in size to the GC) and use a tartar 72" finish mower without any problems. Naturally it would be really working the tractor if the grass gets too tall or is even slightly wet. It does not "push" the tractor around. I ussually take off the FEL when I mow. You can definitely feel that it is back there though. Another issue could arise if your property is sloped or hilly.
I probably should have led with that. My front yard is 2 acres at 25 degrees.
   / Rear Finish Mower Sizing. Want 72" on MF - GC1720 #6
My 72” finish mower weighs 750 pounds and it’s too much for my b7200. The power isn’t enough and the mower is too heavy. You’ve got more power and will probably be fine if the grass is kept under control. If the ground is flat the weight might be alright. Edit, I just saw your last post. Unless you get a really light mower I don’t think it’s going to workout for you.
   / Rear Finish Mower Sizing. Want 72" on MF - GC1720 #7
i used a 72" northern tool finish mower on the back of a 18hp new holland rated at 14 pto hp for a summer. i was surprised how well it did. only cut dry grass, but healthy green, and no more than 2" of cut. i preferred to remove the fel. it was my front yard about an acre about half mowed going backwards for the zero turn effect.
the craftsman rider, 18hp and 42" deck i used the summer be fore that had less take down power!
i think you'll be fine.
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
gravely riding mower (A55758)
gravely riding...
