Rear End Loader?
   / Rear End Loader? #12
I built this rear bucket for my Wards Garden tractor. Reason for going to rear mount was mostly expense and simplicity. Front loader would have been more work and steel for an awkward frame mounting system. And I would have had to add secondary hydraulic system. I figured a front loader would have cost $1300 - $1500 to build. I have about $450 in the rear loader.
The rear blade is raised by one cylinder powered by the HST. I put quick couplers on the existing spool valve that enabled me to switch from the little existing implement raise/lower cylinder to the rear bucket. The rear loader frame was attached to a modified sleeve hitch bar (2 point attachment to rear axle) and a homemade adjustable top link. The bucket is powered up and down hydraulically and manually dumped via the go-kart disc brake which is activated with truck emergency brake cable connected to an over-center lever.
R Bucket Dn.JPG R Bucket Up.JPG R Bucket Dump.JPG R Bucket Mount.JPG R Bucket Counterweight.JPG
Overall I was pleased with the outcome and operation but none-the-less the unit has its limitations.
Without powered curl, normal loader operation was modified and a bit cumbersome. I'd have to push/scrape into the pile, go forward, push the bucket flat on the ground, continue to go forward and rock the bucket back (curled) to place the load to the rear of the bucket so I could clear the front portion of the bucket for more material.
Capacity was an issue. The rear loader worked great for turning compost piles, moving leaves and other light to moderate loads. I could pick up a full bucket of soil but the top link was attached to the back of the HST and heavy loads would rotate the HST in its mounts.
Neck strain was the other issue. It takes a lot of looking over the shoulder to operate and this becomes very tiresome after a couple of hours.
The latter was the final straw. The operation shortcoming was awkward but accetable after some practice and the top link attachment could have been modified, but the constant head tweak is the rear loaders biggest downfall.
In the end I'm glad I built it. I solved all the problems by finally breaking down and buying a BX23 loader/backhoe. Now I have two tractors!
   / Rear End Loader? #13
Two tractors are better than one!
Kudos to your building efforts and congrats on the new tractor. Really appreciate you sharing the pics.
   / Rear End Loader? #14
RayCo said:
I came across this page last night and found it, I don't know, interesting I guess. :) Does such an item exist? Is it useful? I can't really see this succeeding in reality.
There have been a few threads on this which might provide some additional info...don't know if they will come through OK
http://www.tractorbynet.com/forums/attachments/72077-rear-loader-2.html?highlight=3pth+loader
http://www.tractorbynet.com/forums/build-yourself/78477-bucket-loader-three-point-hitch.html
http://www.tractorbynet.com/forums/attachments/65134-anybody-used-rear-mount-loader.html
While they are not very common and for the most part an FEL is nicer, they can be really nice to use and can lift a lot more than a standard FEL...unless you happen to have a NH bidirectional :)
   / Rear End Loader? #15
This is an old conversation but still want to post some pictures. Because of high prices of hydraulics these rear-end loaders were widely used in Finland in the 60's, and 70's. We had several commercial makers here and rear end loaders were used even in digging. The older models had cylinder only for lifting the joint and scoop had only locking mechanism. When the lock was released the scoop was emptied, the balance of scoop swang the empty scoop back in locked position. Just put word 'takakuormaaja' or 'takakuormain' in google picture search and you get more hits. Here is some:
"Farmi" http://www.elisanet.fi/sami80.koivisto/Takakuormaaja(Farmi).JPG
"Farmi" again attached to Fordson Major. Text in picture says "Lifting capacity 700kg's and lifting height 280 cm. Farmi takakuormain -65
"Normet" http://www.uurastajan.com/mahtikuormain1.jpg
"Renki" Findit.fi - support
"Peto" (beast) Eka Peto ? MasinistiWiki
Found a video: 'Peto' in action http://www.youtube.com/watch?v=0j6V85jnJLE This model has 2000kg / 3m lifting capacity.
   / Rear End Loader? #16
Man... I haven't seen one of those in years. And by one... I mean one. That's all I've ever seen. It was on a dealers lot in Arkansas.
   / Rear End Loader?
That was quite interesting. Thank you flyingfinn.
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2019 Toyota Rav4 AWD SUV (A55853)
2019 Toyota Rav4...
1996 Timpte 46ft Hopper (A55315)
1996 Timpte 46ft...
2003 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55852)
2003 Chevrolet...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
