Rear Differential lock
   / Rear Differential lock #1
drjay9051
Morriston, Fl. 40 miles west of Ocala. More cows
Kioti DK 40 HST
New owner of CK25. Great tractor. No info in manual on the differential lock. I have depressed pedal while in both two wheel and four wheel drive and cannot feel any difference. Am I missing something. I had tried while in 4 wheel while pushing heavy load and wheels wer spinning, still no difference that I could tell. Help is appreciated. Also, this is my first tractor and I am not sure how to tell if the fittings are greased properly. Do I stop after a pump or two or keep injecting grease till it squirts out or what? Silly question but hey Im a newbie
Jay
   / Rear Differential lock #2
The diff lock simply makes both rear wheels rotate at the same speed. A typical open differential will let one wheel spin all by itself. So if both rear wheels were slipping at the same time then it is working properly. A locked rear end is not as effective as engaging the front axle. You'll want to do thast for loader work.
I am an admitted greasaholic. I pump grease in until I see eveidence of grease exiting the fitting. Grease is cheap and it doesn't hurt to put too much grease in a joint. It just gets messier.
   / Rear Differential lock #3
Highbeams description is very good, if I may add one point. I am quite sure the differential lock can't be engaged until one rear tire is spinning, then you can press down on the lock and engage the other rear tire. I find it most useful when traveling in my rock bed(yard) and having the tractor slightly highside itself on two opposite corner tires, one front and one back and the tractor wheels just sit there and spin, with the tractor not moving at all. Thats when I press the diff lock and away we go, works swell.
   / Rear Differential lock #4
The diff lock lever has to be pushed all the way down. Sometimes I'll push on it and it doesn't go all the way down and nothing will happen. I just push a little more and they lock. I've been thinking about making the lever longer to get better access to it.
   / Rear Differential lock #5
drjay there are some places with grease fittings where you can damage things if you put too much in, perhaps the two on the middle of the front axle and similar fittings that use seals to keep the grease in, maybe don't go too much grease in those places...
Mike
   / Rear Differential lock #6
"I am quite sure the differential lock can't be engaged until one rear tire is spinning, then you can press down on the lock and engage the other rear tire."
Interesting. My understanding is that the diff lock lever actually jams a pin in the planetaries which locks the two wheels together. When you release the lever the pin will pop out of its spot with an audible click. Given that it is a rigid, on-off style joining of the two rear wheels I would highly recommend that you allow all the wheels to stop spinning before engaging the pedal to prevent the shock load. Now if both wheels are rolling along at the same speed then it is entirely advisable to engage the diff lock at that time before encountering the obstacle which might allow one rear wheel to slip. But be warned, steering will be difficult since the differential will not allow the inner wheel to rotate more slowly than the outer.
With the diff locked, front wheel drive engaged, and in low range with decent rpm the Kioti is hard to stop.
   / Rear Differential lock #7
DR Jay
I've found you have to be a little aggressive sometimes to lock the diff. and I have to keep my right foot on it to keep it engaged. For the most part it goes in ok.
   / Rear Differential lock #8
I could be wrong Highbeam, it certainly would not be the first time! I just remember reading on these forums somewhere, and someone had diagrams and stuff to show exactly how it worked. And if my memory serves correctly, you can press the pedal anytime you want, but the lock won't engage until one wheel slips. It could of been in another mfg forum, and I used to do just as you say, press the lock before I thought I needed it. But for some time I have been just pressing the lock only if the extra traction is needed with the wheel already spinning and it works fine, no chattering or anything like that. As I said, its just something in the back of my head that I read somewhere,,,I could be way off,,,,
   / Rear Differential lock #9
Highbeam describes it correctly as I remember. It even feels like that is what's happening. If you engage while one tire is spinning, you should feel the clunk or engagement. The lever usually even moves further down. When resistance disappears or the wheels are moving freely and your not applying pressure, the lever will pop back up. I usually engage if I anticipate the need or stop if one wheel slips and then ease into it again. Where I work, we have a large New Holland that has an electrically operated diff lock. Right now it is getting repaired due to improper use. The repair facility said the lock was engaged and then used on a hard surface, (no slippage), or engaged and driven for extended periods which it is not designed for. 3500.00 is the estimate to repair. I'd much rather have the mechanical. Flipping a switch is just a little too convenient - maybe. Just my two cents for the day....
   / Rear Differential lock #10
Highbeam, I think you described it well.
I very infrequently use the differential lock, but yesterday it happens that I was backdragging uphill and rears were slipping. I engaged the lock while stopped and stood on it while backdragging. Then, would release it and noticed while going forward downhill again a distinct CLICK ... after repeating the procedure several times, I definately associated the CLICK with the differential lock disengaging.
I never think to engage the lock until I discover rear tires spinning, then stop, engage, and begin again. That's how I use it.
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2013 Chevy 3500 Mechanic Body (A47384)
2013 Chevy 3500...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
FORD 7600 TRACTOR (A51243)
FORD 7600 TRACTOR...
SET OF (2) TITAN HI-TRACTION TRACTOR TIRES/WHEELS (A51244)
SET OF (2) TITAN...
3 pt Sprayer (A50515)
