rear diff wont lock?
/ rear diff wont lock? #1
ngwilson91
Hi
i just bought a cub cadet 7200 tractor with 500 hours on it and i cant get the rear wheels to lock. i think im doing everything right. any idea what the problem could be? or what might be wrong?
/ rear diff wont lock? #2
I've watched many drivers that never use it! My first thoughts would be to start lubing the lever at the pivot to see if any movement can be gained.
/ rear diff wont lock? #3
hello i would sproy the button with pb blaster mite be rusted . i had my diff lock locked in couldnt get it out i sprayed the heck out of it and it workes now.
i will try putting some lube on it but it seems to be moving enough at where it piviots
/ rear diff wont lock? #5
the diff pedal has a button it pushes on that is what rusted on me need to spray button.
/ rear diff wont lock? #6
Not the same tractor but on my tractor you need to turn the steering wheel left and right to get the dogs to line up on the diff lock. You can accomplish the same thing buy spinning the tires.
Chris
/ rear diff wont lock? #7
Yes, my JD often needs a little "gentle" coaxing to get 'em lined up and locked. I just take 'er ahead an inch or two and back a couple and it usually locks in when you go ahead again. Sometimes it takes a tad more aggressive action of the same sort but not much. It has never locked in on the first kick-down, you have to ask at least twice. Once in, it's worth its weight in gold, as they say!! Saved me certain grief more times than I like to recall!!
CHEERS!
. . tug
Ford Tailgate Themed Wall Decoration (A61569)
Ford Tailgate...
John Deere Hood Guard (A63116)
John Deere Hood...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A62131)
UNUSED PAIR OF 76"...
UNUSED MGY-50KW FUEL HEATER (A62131)
UNUSED MGY-50KW...
2018 Towmaster TC-16 10 Ton Tag A Long Trailer (A61568)
2018 Towmaster...
2018 Forest River Cherokee Trailer, VIN # 4X4FCKB26JX130699 (A61166)
2018 Forest River...
