Rear crank seal
   / Rear crank seal #1
Fornshell
Bronze Member
JD2240
I have a JD 2240. Just installed rear crank seal from JD. Put a little oil on seal on installation. Has a small leak. Just wondering if this seal should have been installed dry. I used proper install tool for the seal. Don't know why it would be leaking, any help appreciated.
   / Rear crank seal #2
Could be a slight hardly noticeable grove worn where the seal rides. Might check and see if they offer a speedi-sleeve kit for that application. If they don't NAPA or a good bearing supply should. Just need to mic the area where the seal rides for the wear sleeve. Then the O.D of the seal, they can match the I.D. to the wear sleeve.
   / Rear crank seal
Ok thanks for the information. I'll have to mic everything see where I'm at.
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
1982 LeeBoy Motor Grader (A55218)
1982 LeeBoy Motor...
2015 KENWORTH T680 SLEEPER (A54607)
2015 KENWORTH T680...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
Carnival Ticket Booth (A51691)
Carnival Ticket...
