Rear blower on front 3 point hitch?
   / Rear blower on front 3 point hitch? #1
corey9212
Platinum Member
Red Deer County, AB
2015 John Deere 3046R
Hello, I was contemplating on putting a 3 point hitch on the front of the tractor with a front PTO, my question is if I got a 3 point snow blower could I use it as a front mount snow blower? Could it handle the stresses of being pushed rather than pulled?
Thank you.
Corey
   / Rear blower on front 3 point hitch? #2
You can put a rear blower on the front. If you don't have a front PTO you will need to get a reverser gear box and put it behind your rear PTO and run a long driveline under the tractor. If you have a front PTO (like my tractor does) you get rid of all the extra drivelines out the back and under the tractor but you will probably still need a reverser gear box.
BWSwede
You can put a rear blower on the front. If you don't have a front PTO you will need to get a reverser gear box and put it behind your rear PTO and run a long driveline under the tractor. If you have a front PTO (like my tractor does) you get rid of all the extra drivelines out the back and under the tractor but you will probably still need a reverser gear box. BWSwede
Thank you, so the front PTO spins the opposite direction I take it? The front 3 point hitch and front PTO are field installed options I am considering.
   / Rear blower on front 3 point hitch? #4
TBN user grsthegreat, has a loader mounted hydraulic blower, it is run by a rear three point mounted hydraulic power unit (tank and pump on back, run by rear PTO), hoses run up front to the blower.
He has pics on here somewhere, I've seen them before.
He can swap from the blower to front bucket in a couple minutes, if I was looking for a front blower, that's what I would be interested in.
Maybe he will chime in, or you can find the pics.
   / Rear blower on front 3 point hitch? #5
Duh, I never thought of a hydraulic motor. What a great idea.
TBN user grsthegreat, has a loader mounted hydraulic blower, it is run by a rear three point mounted hydraulic power unit (tank and pump on back, run by rear PTO), hoses run up front to the blower. He has pics on here somewhere, I've seen them before. He can swap from the blower to front bucket in a couple minutes, if I was looking for a front blower, that's what I would be interested in. Maybe he will chime in, or you can find the pics.
That would be cool to see, I was thinking more to keep compact and maneuverable if it was on the front 3 point it would be closer to the tractor instead of way out in front like the loader would be.
   / Rear blower on front 3 point hitch? #7
I have a Kubota L39TBL that doesn't have a mid PTO so I added a rear pump and skid steer snow blower (Loftness 60")(39 has quick release FEL) Works great. Current project is rebuilding an Arians tractor front blower(48") and adding hydraulic motor. about to test frow reate versus rpm etc.
   / Rear blower on front 3 point hitch? #8
Don't forget rear PTO is 540RPM.. front PTO is 2000RPM
My rear is 540/540E/1000E because it's multi speed I would have figured the front would be multi speed as well just programmed from the computer like everything else in the tractor.
   / Rear blower on front 3 point hitch? #10
From what i can see in the brochure, it is 1000RPM
378747 (A51572)
378747 (A51572)
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
