Rear Blade
   / Rear Blade #1
richsei
Kansas
Kubota, B2410
I have just signed by name on the doted line for a new B2410HSD That will be delivered on fri the 3-2-01.
I was looking over the info. for the B2410 and on the implement chart under the Rear Blade it says that it requires B2002 (Main Frame Kit) what is this and do i need it to use a rear blade.
richsei
<P ID="edit"><FONT SIZE=-1>Edited by richsei on 02/27/01 09:47 PM (server time).</FONT></P>
   / Rear Blade #2
richsei,
Welcome to TBN and congratulation on your new B2410HSE. /w3tcompact/icons/smile.gif
Did you also purchase a FEL for your new investment?
What are you planing to do w/the rear blade..light duty or heavy duty work.
Least you only have a couple of sleepless nights a head of you compare to other that had to wait weeks or a month before there bundle of joy arrives home..hang in there. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
   / Rear Blade #3
richsei-
First if all, congratulations on your purchase, hopefully you'll find something to keep you occupied until it arrives/w3tcompact/icons/smile.gif.
It seems like I remember someone making mention of that main frame kit before, but, there is no mention of it in my L3000 manual.
Good Luck.
Paul
   / Rear Blade #4
I asked the same question about two months ago and didn't actually get a definite answer. Now that I own a B2410HSD (and owner's manual), I'll tackle it for you.
The owner's manual, Implement limitations section, DOES NOT list a sub-frame for the rear blade. (Sub frames are listed for back hoe, front blade, loader, etc.). It does list a max. cutting width of 60" and a max. weight of 400 lb.
Looks like the B-series brochure is not correct about the sub-frame being necessary for a rear blade.
- Rob
   / Rear Blade
Wheeldog
Thinks for the help. My 2410 will have a FEL and a mid mount mower. The blade will be used for snow removel and landscacing.
Do you know if the 2410 has auto bleed on the fuel system.
Thinks again for the help.
richsei
   / Rear Blade #6
Richsei,
Your welcome. As for the auto-bleed fuel system, I don't believe the B2410 has it. However, the owner's manual lists the bleeding procedure only as: "1) Fill the fuel tank with fuel., and 2) Start the engine and run for about 30 seconds, and then stop the engine." This seems like no big deal, but I'm a diesel tractor newbie and may be missing something here.
Just curious, what led you to get the 2WD version of the B2410? Are you planning on loaded tires plus 3-pt. ballast for use with the loader?
- Rob
   / Rear Blade
Wheeldog
I guess I typed in the wrong model it is a B2410HSD not a B2410HSE. Sory about that.
Thanks again Wheeldog for the help. I'll have to send in some pic. when I get it.
richsei
   / Rear Blade #8
The 2410 does have an auto bleed system. As for the main frame kit, you need a B2002 and B2005 to have a complete rear blade assembly. Most dealers include the kit(s) in the price of the blade. The B2005 is the moldboard and the B2002 is the A-frame.
   / Rear Blade #9
Thanks for the good information - that's what you get for listening to a new owner like ME I guess.
I'm a little confused about the whole rear blade deal. Are you saying that in order to get a complete Kubota rear blade assembly you must order two separate part numbers? The Kubota rear blade attaches only at the 3ph (no tie to the tractor frame), correct?
- Rob
   / Rear Blade
Snell
So if I use a rear blade made by someone else do I need this kit.
richsei
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2014 FREIGHTLINER CASCADIA DAY CAB (A52577)
2014 FREIGHTLINER...
2020 Isuzu NPR Garbage Truck (A52377)
2020 Isuzu NPR...
Truck Wheel Fenders (A51692)
Truck Wheel...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
1065 (A53342)
1065 (A53342)
