Grading rear blade
/ rear blade #1
wichiwichi
Farmersville, TX
Kubota B7500DT,June 2000
Has anyone used a 6 ft blade with a B7500? I've used a 5 ft with no problem but was wondering on 6 ft. Local dealer has a sun faded 6 cheaper than I can order a 5. Any input would be apreciated.
/ rear blade #3
I have a 6 ft rear blade on my B2710 and it works just fine. This is the same blade that I had on my previous tractor B2400. The extra size comes in real handy when plowing snow.
/ rear blade #4
Like Mike said - grab it. I haven't used mine for snow just yet, but I picked up a 6 footer last Spring. Mine is a closeout from TSC, and was cheap. It's built much heavier than the 5 foot model I got at Central Tractor for my Ford 1210. I also figured I could cut some off each end if necessary.
The 5 footer had a plate of mebbe 1/4" thickness for the rotation. There were holes to drop a pin through to set the angle of the blade. After some use, it was necessary to double the thickness of the plate. I also went with a slightly stouter pin. Worked fine ever since.
I have used the 6 footer with the B7500 to spread some stone, sand and topsoil. The extra weight of the blade seemed to make it work better than the smaller, shorter one. I'm anxious to give it a whirl in the snow. Hope we get a real Winter this time around........................chim
/ rear blade #5
My 5' blade - blower on front
/ rear blade #6
Use it for this..
/ rear blade #7
and this...
/ rear blade #8
ready and waitin' for some snow...
/ rear blade #9
i have a 6 ft on my b2400 it works ok but the way it is made i can.t turn it around to push, it can be turned but it hits my 3 pt. lift arms
/ rear blade #10
Frank,
I had that blade on my tractor (that's why it's painted green). I shortened the top link enough so the blade would clear the lower links. If you shorten the top link a little, and lower the blade close to the ground it will turn 360 degrees. You may have to lift the back of the blade when turning it to take care of the play.
I swapped your blade for one like the one snowman has only 72".
Bud
/ rear blade #11
Frank,
If you have your tractor setting level and you turn the blade to a 30 degree angle, does the back of the blade hit the ground before the front? It looks like it would in the picture in (B2400 price).
Bud
/ rear blade #12
I use a Kodiak 6' rear blade on my 7500. Pushed / pulled dirt and driveway fill around. The 7500 has no problem with it and I am also waiting for snow to see how it will perform.
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
Caterpillar Blade Control Service Manuals (A63117)
Caterpillar Blade...
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
2020 McCloskey R155 Trommel Screener (A61572)
2020 McCloskey...
