Grading Rear blade width for a BX 2230
   / Rear blade width for a BX 2230 #11
Ive got a 60" Landpride on my BX23 that I plow snow with. Im happy with the width. When fully angled, it covers the tires plus about 4-6" on each side. The width is good but I wish it was higher.
   / Rear blade width for a BX 2230 #12
Where are you guys finding the shorter toplinks. I need one for my RB60.
Thanks Guys!!
Sounds like the 60" King Kutter gets the nod after xmas.
   / Rear blade width for a BX 2230 #16
I have much, much larger tractors than most posters here, but a good rule of thumb on width of any implement is to buy the widest implement that will clear the outside edge of the sidewall of the rear tires at their most outset position.
Example. If the rear width of your tractor is(measured from outside sidewall to outside sidewall) say, 58", then you should by an implement width of no less than 60".
Remember, wider implements, especially those that engage the ground consume more power and require an initial heavier, more tractive unit the wider they get.
A good example of implements is my Lucknow 78" rear blower that I had on my L5030 that's now on the M9. Maximum outset sidewall to sidewall outside width was 76" so the 78 worked fine as it was 1" wider than the outside walls of the tires and allowing sway in the 3 PH linkage, was right on. The M9's Minimum inset sidewall to sidewall outside is 78", That's inset not outset. The 78 can be used with the M9, but the M9 is technically overpowered for the 78. This summer, I'll have to extend the side sheets of the 78 to at least 80" or get another, BIGGER, blower. If I modify the 78 to at least 80", I still have to watch how I push the blower as the M9 has at least 30 horses more than the maximum rating of the 78 which is 50.
The rule-of-thumb works for all implements excepting backhoes and other hydraulically operated devices. with those devices, weight of the implement versus how much weight the tractor can carry itself without structural damage is the limiting factor.
I do have the Pats Easy Change that effectively makes the lower lift arms almost 4" longer. ????? whats this
   / Rear blade width for a BX 2230 #18
They are the attachments that go on the end of the lower arms of the TPH lift arms that make changing implements almost effortless and a lot faster, saves a lot of skinned knuckles and foul language in the air. They are sponsors here on this site if you decide to order a set. Just click on the link and you can see what they are. Link
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
2010 Ford F150 Single Cab Pickup Truck (A55973)
2010 Ford F150...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
