Grading Rear blade width for a BX 2230
   / Rear blade width for a BX 2230 #1
PERCOS2
PA
Kubota BX2230
I am looking to purchase a rear blade for my BX 2230. TSC has king kutter blades in 54,60, and 72" widths. what would you guys suggest?
   / Rear blade width for a BX 2230 #2
I got a 60"er per dealer recommendation when I bought my BX23. Works good for me ... all dirt work, no snow.
   / Rear blade width for a BX 2230 #3
I think it depends on what you are going to use it for. I have a 60 for my BX22 it is easy to load it with too much dirt and stall the tractor. I suspect snow woould do the same (it don't snow here) I would suggest a 54 myself.
   / Rear blade width for a BX 2230 #4
I have a 60" behind my bx1500. Moves snow and dirt without a problem /forums/images/graemlins/grin.gif
   / Rear blade width for a BX 2230 #5
I have a 60" Frontier rear blade for my 2230. So far, it has worked very well. Have not had any stall problems at all moving snow.
   / Rear blade width for a BX 2230 #6
I'm very happy with a LandPride RB1560 (60") on a BX2230. Use it mostly for snow removal and leveling gravel on driveway and beach. IMO, 72" would be too big. Also, since the RB1560 is a full size Cat1 RB, you need to shorten the 3PH lift (as described elsewhere on TBN) to get more height.
In addition, I welded up some brackets and added a couple of Meyers snow plow skids. Blade height can be changed in 1/8" increments by redistributing a bunch of washers on the vertical shaft of each skid.
   / Rear blade width for a BX 2230 #7
I have a rear blade that I have only use for snow so far and I was thinking it was 60", but I just went out and measured it and it's 72". I use it on my BX2200 and I can turn all the way around without hitting anything it's cat1 and I didn't have to do anything to get it to lift. I do have the Pats Easy Change that effectively makes the lower lift arms almost 4" longer.
   / Rear blade width for a BX 2230 #8
On my BX23, I had a Woods RB60 (60") that worked just fine. However to make installation on the 3pt easier, I reversed the top pins so they were pointing in instead of out. Kubota claims that the BX23 has a CAT 1 hitch but the spacing seems to be a little tight.
Jim.
   / Rear blade width for a BX 2230 #9
I also have a Woods RB60 but have left the pins pointing out. I did not find this as much of an issue as toplink size- a shorter one was needed.
I have used a 72 behind my BX2200 (normally used on my 2410) but would agree that this is alot of blade for anything but light grading.
   / Rear blade width for a BX 2230 #10
I've been using a 60" Midwest behind out BX2230 and its about perfect. I tried a 72" model but it was just a bit too much and with snow it was stalling out the BX when pushing backwards.
1268 (A50490)
1268 (A50490)
2021 SKYJACK SJ3219 ELECTRIC SCISSOR LIFT (A51242)
2021 SKYJACK...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
CATERPILLAR 336FL EXCAVATOR (A51242)
CATERPILLAR 336FL...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
