Rear Blade Rear blade weight
   / Rear blade weight #1
oosik
Epic Contributor
AMBER, WA
2009 Kubota M6040
I currently have a Land Pride RB3596 @ 566# on the 3-point of my M6040. It does great for plowing snow but will do little to nothing on my concrete hard driveway in the summer. Even with the hydraulic top link extended - i.e. max cutting angle for the rear blade - it just, more or less, bounces along.
My thought - I NEED MORE WEIGHT. Sooo.... what's your suggestion for the max weight I can add to this blade without causing damage to its structure/attachment points.
I'm also considering a new - and much heavier - rear blade. Rhino 950, 8 foot, at around 1000#, after the manual kits are installed.
The reason for this query is obvious - I can add XX amount of weight to my existing blade for almost nothing - the new Rhino blade will set me back around $3500.
Your suggestions and experiences will be greatly appreciated. Oosik
   / Rear blade weight #2
I'm a newbie, but wonder if it would help to scarify the surface first with a box blade or some ripper and then use the rear blade to grade it.
   / Rear blade weight #3
Pics of your current blade?
   / Rear blade weight #4
Yep. Without pics it's hard for anyone to recommend adding weight.
In most cases the frame of a blade is built to withstand the forces the weight of the blade will create. Add weight, adds forces exerted = bent blade.
   / Rear blade weight
OB - YES, it very definitely helps. I have a land plane grading scraper w/scarifiers that I use and its the only way to break the surface and then regrade successfully.
However - since I was not very succinct in the original post - I will elaborate.
After 35 years of use, the mile long gravel driveway has an awful lot of the "surface material" relocated to the ditches. One of the primary uses of a heavier rear blade would be to bring this material back out of the ditches - and onto the driving surface. There I could redistribute it with the rear blade and LPGS.
I'm just concerned - that if I add enough weight to my existing rear blade to make it anyway effective - it will cause considerable damage to the structure and attachment points.
Right now I'm leaning towards selling the existing blade and purchasing the heavier Rhino. However, I'm open to suggestions and thank you for your input.
   / Rear blade weight #6
Wise beyond your newb self title! That's the answer. Rippers or a serrated blade.
   / Rear blade weight
View attachment 499761View attachment 499758
Well, sorry - this is the best I can do at the moment. Its still too dark out in the carport stall to get a close-up pic. I tried.
However - it just the standard Land Pride RB3596.
   / Rear blade weight #8
No worries.
After more thought, I think you would be better served longterm by purchasing a heavier blade. It's a tool that you would likely keep the rest of your life. Unless you step up in tractor size.
If you add weight to this blade and bend it you won't have much to sell.
   / Rear blade weight #9
I agree with Richard, sell it while it's in good shape and get a heavier built blade. I highly recommend that you get skid shoes and at a minimum of hydraulic blade angle. Set your top link and then switch over to the blade angle.
Good luck with your decision.
   / Rear blade weight
Thanks to all..... Man, its darn cold outside. Right now at 8am its 14F. I slipped out with my little camera - hoping to get a closeup and all I got was a black rectangle. And here I thought I had pics on file of every conceivable implement, situation etc,etc.
I will definitely get pics of the new blade when it get here. Again thanks...........
BROWN MPT-30 LOT NUMBER 67 (A53084)
BROWN MPT-30 LOT...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
Pallet of (6) 8 Lug Misc Wheels (A51573)
Pallet of (6) 8...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
