Rear blade skid shoes
   / Rear blade skid shoes #1
Chilly807
Elite Member
Nova Scotia
Kubota L3400DT
I spent part of the day adding skid shoes to my rear blade, snow can't be far off now.
3/8 plates, dished 3/4 inch, I used 1/8 inch 7018 at 115 amps DCEP. It's the first time I've used the larger 7018 rods with this welder, I'm pretty happy with the way they worked.
The rest of the job was done with the Miller 180, my out-of-position welding still isn't that great with the stick, I have more confidence in my abilities with the MIG. Still getting a fair bit of spatter, but that may be the wire I'm using.
Sean
   / Rear blade skid shoes #2
Before you know it your welding will be looking like laid dimes...nice beefy well done job. :)
I'm learning to control the puddle a bit better with practice, every so often there's a "light bulb moment".
Thanks Thomas, I think it'll hold up to the 3400 at least.
Sean
   / Rear blade skid shoes #4
Nice work. How did you dish the plates? Hydraulic press?
I just made some "overshoes" for my snow blower skids. The standard skids are a little narrow, 2 inches, so I bent some 4 inch wide plates and welded on some bolts to attach them to the original skids.
Hopefully she'll slide a little easier with the wider skids.
   / Rear blade skid shoes #5
Good job! You won't have to worry about them wearing out any time soon. Next you will be building side plates for it. Wish I could weld that good.
Hydraulic press.. I have access to a 75 ton press at work. It took about 40 tons to get that much deflection, with the outer edge of the disc supported in a piece of pipe.
Sean
It's surprising how fast they DO wear out, I'll probably end up hard-facing them during the winter unless we don't get much snow.
I try to get as much practice as I can, I've learned quite a bit from the guys here. I hadn't stick welded in 25 years, picked up a used AC/DC a few months ago. I find the MIG is easier to use for doing verticals and overhead welds.
I built wider skids for my walk-behind blower a few years ago, it was fine in soft powder, but wanted to ride up on the snow in heavy wet stuff. A tractor blower should be heavy enough that you won't have that problem.
Sean
   / Rear blade skid shoes #8
Nice. I keep thinking about making shoes for my 10' blade on my truck. It's set up for shoes but so far I haven't gotten around to it. Once the ground freezes they are not needed so for now I just feather the height of the blade.
   / Rear blade skid shoes #9
i just re-did the skids on my Boss V Plow. Very similar and yayyy it's done.
I patterned these after truck shoes. They're a bit smaller, 4.5 inch as opposed to 6 inch. The truck shoes were anywhere from $25 to $50 each, and I still would have had to buy the pipe and steel rod. The whole thing ended up costing me about $30.
Sean
CFG Industrial SAII100 (A50123)
CFG Industrial...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
7ft Fork Extensions (A51691)
7ft Fork...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
