Rear Blade Rear Blade or Bucket.??
   / Rear Blade or Bucket.??
If I get a blade (most likely will), will I want to attach it to push forward (drag) or push in reverse.??
   / Rear Blade or Bucket.?? #12
The Blade I have rotates 360deg, you can alter it's direction and lock it with a pin. Then Pull or Push (backwards) as you see fit.
I plow snow with mine backwards with the blade at an angle so as to have the snow pile wider than my 50" tracks. 2 passes on the drive ways and 3-4 on the Gravel access road (comunity road), 4-5 for the Main county road.
I don't pull the blade in snow as I want all the traction and don't want to compress the snow into the drive or roads.
This picture might help, mine is the 1572 as pictured. It tilts and rotates
http://www.landpride.com/main_products/main_rb.html
   / Rear Blade or Bucket.?? #13
For smaller areas, a blade or bucket will work fine. When it comes to a long driveway, a blade in front or back is the way to go. Then clean up with a bucket.
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
John Deere 5103 (A53317)
John Deere 5103...
HYSTER P200B ROUGH TERRIAN FORKLIFT (A55745)
HYSTER P200B ROUGH...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
