rear blade hydraulics- lesson learned. LOL
   / rear blade hydraulics- lesson learned. LOL #1
mopardude318
Platinum Member
Hollister Ca
Kubota M7060 HD12 Oliver 550
I was told NOT to do this by the One and Only no less, but I did it anyway. My rear blade came with the 3 hydraulics and one manual selector valve already installed. I thought I would have the great idea and buy ANOTHER manual selector valve ($170) and the fittings and some hose (another $130). I made same spacers, got some longer bolts and mounted it on the opposite side of the first selector valve. Then I hard lined the valves together. Here's some pics.
Everything works fine, works great. But like was mentioned to me, having to get off the tractor and turn these selector valves for each function will get old in 5 minutes. And that's exactly what happened...in 5 minutes. Needless to say, I'll be scrapping this good idea I thought I had, and I'll be ordering the triple diverter system from Brian @ Fit-Rite. This $340 dollar idea will probably sit on the shelf till the end of time. ;/ I didn't listen, but I learned!
   / rear blade hydraulics- lesson learned. LOL #2
Thanks for sharing!
   / rear blade hydraulics- lesson learned. LOL #3
You are good at fabricating,
add a couple of cable actuators to the selectors and mount a lever or 2 on your tractor.
Alternatively a couple of small linear actuators.
   / rear blade hydraulics- lesson learned. LOL #4
A stick with a weight on thr end and a nice mount by the seat....or cables.
   / rear blade hydraulics- lesson learned. LOL #5
I have a single selector on my rear blade.
I was able to mount it in a location that when I raise the blade, I can turn around and reach the lever.
But since you are thinking of going triple diverter setup....a cheaper option may be just what you have there, only relocated to the tractor. Turn your one free remote into 3 with those levers
   / rear blade hydraulics- lesson learned. LOL #7
WoW! That looks like the KRAKEN'S brother. You did an exceptionally clean build. Can you remember from day to day how to operate it. LOL
   / rear blade hydraulics- lesson learned. LOL #8
Great job!
Can I ask how you made the hard lines?
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
1R CULTIVATOR (A51247)
TRUCK BED PORTABLE FUEL TANK (A51248)
TRUCK BED PORTABLE...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2017 ASV VT-70 SKID STEER (A51246)
2017 ASV VT-70...
