Rear blade for snow on gravel, pipe or rubber mat?
   / Rear blade for snow on gravel, pipe or rubber mat? #61
Didn't mention what the driveway was dirt with grass or gravel or paved, however between the teeth on a landscape rake would leave a lot of residue unless you have some sort of blade or mold board at the bottom.
Lots of great ideas, thanks! With some "unevenness" to the gravel drive, I would think grader blade shoes would still have me shaving high points of gravel if not frozen. I guess I'm still leaning towards the steel pipe on the blade, or below the blade with welded tabs for mounting through bolt holes. I was thinking of 2" or 2.5" O.D. pipe so as not to be too small. Anyone go bigger pipe than 2.5"?
   / Rear blade for snow on gravel, pipe or rubber mat? #63
The larger the pipe the less likely to scrape gravel.
However, the larger the pipe the more snow it will pack down and ride over.
   / Rear blade for snow on gravel, pipe or rubber mat? #64
What works really well is 'edge tamers'. Very clever product!
They clamp on and are affordable.
Just like adding a pair of skis.
a pair on a 4 ft bucket or perhaps 3 on wider ones.
I DIY'd a pair for my 60" snow blower and never need to rake any gravel anymore.
   / Rear blade for snow on gravel, pipe or rubber mat? #65
Those edge tamers look nice.
Was thinking of these for the bucket, though not sure on the bolt and handle
And then there are these, though bolt on
I used these for my snowblower. Run really nice in that application.
   / Rear blade for snow on gravel, pipe or rubber mat? #66
I use three 3" Edge Tamers for my 72" loader bucket. Two at sides plus 1 in middle to prevent scalping. Have a lot of uneven areas. Works very well. R2Manufacturing has been xlnt to work with. Can also get handy extensions to carry logs, etc. with. I use them for some things in the summer as well.
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
UNUSED RAYTREE RMAU2 AUGER (A51248)
UNUSED RAYTREE...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
