Rear Blade Rear Blade for JD 5303
   / Rear Blade for JD 5303
I can not seem to get the file to post. Everytime it will go through the upload function and then end with an error/red exclamation mark. Any ideas what is going on? The file is 1.4 MB.
   / Rear Blade for JD 5303 #12
The file might need re-sized.
Another option, instead of using the quick picture inserter, go to advanced at the bottom, and then scroll down and click "manage attachmetns" and try that way. If that dont work........check your PM
Had tried both ways, from mobile device and two different computers. No luck. Responded to your PM.
Thanks.
   / Rear Blade for JD 5303 #14
That is a good price and I have a 7' rear blade for my 35 hp Kubota. I don't have tilt either just 5 angle settings but can adjust the top link and make it do whatever I need it to. Haven't seen any pic but make sure whatever you get is heavy duty with a replaceable wear bar on the blade. I much prefer a rear blade to a box blade and believe it can perform many more tasks in the right hands.
   / Rear Blade for JD 5303 #15
Sorry I cannot help. But something funky is going on.
I downsized the image to ~230k, and still wouldnt let me upload.
Check photo properties, it said it was a locked image since it came from another computer, so I unlocked it.
Still no go.
Opened with paint and made a modification...
Still no go.
But I can upload any of the other images in "my pictures" :confused:
Puzzling. I wanted to get it uploaded, cause others here will be more knowledgable as to what model that blade is, and wether it will hold up to your tractor.
   / Rear Blade for JD 5303 #16
Still no luck. Tried saving as bmp, png, and gif and none of them will go either. Pic must have some setting that is locked out that I cant get to.
I've got one more trick to try though....
   / Rear Blade for JD 5303 #17
I think it is something with the pic uploader on TBN now. Not sure if they are looking into it, but 99% of the pics I post here are off my phone. I just took a pic with my phone and it wont let me upload it.
The test pics I tried earlier are pics that I have already uploaded before. They are the only ones that seem to go through. But I cant get ANY new pics to load now:mur:
   / Rear Blade for JD 5303 #19
Upload it to photobucket. Get the img code and paste it here. I dont think the ETA blade would be enough for that tractor.
   / Rear Blade for JD 5303 #20
Our Xtreme duty scrape blade would be plenty for that tractor and then some. It is rated up to 80HP but isn't close to the same ballpark as the blade the OP is thinking about. The closest blade on the market to ours is probably the Rhino 500 series blade. The Rhino blade is a pretty nice blade but compared to our blade, their 6' is 80 pounds lighter, 7' is 88 pounds lighter and the 8' is 145 pounds lighter. Ours will also be ALOT easier on the wallet.
TIRE & RIM, SKID STEER PLATE, MISC HITCHES & PARTS (A52708)
TIRE & RIM, SKID...
2017 DODGE RAM 2500 (A58214)
2017 DODGE RAM...
2013 Ford F-450 Flatbed Service Truck (A55973)
2013 Ford F-450...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A56435)
2025 Wacker Neuson...
2013 Ford F-250 (A55973)
2013 Ford F-250...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
