Rear blade/box blade
   / Rear blade/box blade #1
Stomper
Saskatchewan, Canada
2017 Kubota L2501
I spent some time in the shop today and turned my rear blade into a box blade. I made the mistake last year of buying a cheap rear blade and it didnt take long for the frame to crap out. The blade if fine but the frame was way to light. I built a new beefy frame with plans to eventually build an accessory for a box blade. I dont have rippers on it but if I find I need them I will make them. Most of the material I will be moving is sandy anyway. I have the blade 1 inch lower than the side. I still have to make skids for it but this is what I have so far. 5 bolts holds it together and it takes 5 minutes to install or remove.
   / Rear blade/box blade #2
Nicely done and rugged. :thumbsup:
   / Rear blade/box blade #3
I like it. Very nice.
Yeah it will definitely work just fine for what I need it to do but I highly doubt it will be as strong as an actual box blade. The best part is it didn’t cost anything. I just used materials that I have been tripping over in my shop.
   / Rear blade/box blade #5
Looks great, do you plan to add rippers at some point?
   / Rear blade/box blade #6
I like it, where do I send mine to have the same thing done to it?:laughing:
Probably will eventually. If I do I will just weld some angle iron clips on the front of the 4x4 tube and install them there
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
John Deere 1025R (A53317)
John Deere 1025R...
2007 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A58017)
2007 INTERNATIONAL...
1995 Ford 3930 50HP Utility Tractor w/ Land Pride RCD1884 84in. Brush Cutter (A55973)
1995 Ford 3930...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
