Rear Ballast SX3100
   / Rear Ballast SX3100 #1
BuilderML
Tolland, CT
CCY SX3100
Was wondering how much weight others might be using for rear ballast on a SX3100?
   / Rear Ballast SX3100 #2
Your rear lift is rated for 1209 lb. per tractordata.com
If you just need some rear ballast for doing loader work 400-600 lb. should work very well.
   / Rear Ballast SX3100 #3
I like to balance the loader capacity with the rear ballast. My lx4900 lifts 2500, I have rear tires loaded which adds 1100, and have a 1500 lb box blade. Loading the rear tires really helps, and is always there.
   / Rear Ballast SX3100 #4
I have loaded tires and I hook up my box blade when I so loader work. It is only a 4' blade and weighs about 250 pounds. It works good unless I have a full bucket of dirt and have to go down hill. The rear tires get a little lite for my taste. I have also strapped 4 cement blocks on my blade and it makes it much safer. So with loaded tires I would say at least 400# and you should be good.
Sent from my iPhone using TractorByNet
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
378563 (A51573)
378563 (A51573)
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
Towable Orchard Sprayer (A51691)
Towable Orchard...
2007 Volvo VNL Truck Tractor (A53472)
2007 Volvo VNL...
