Rear Ballast SX3100
   / Rear Ballast SX3100 #1
BuilderML
Tolland, CT
CCY SX3100
Was wondering how much weight others might be using for rear ballast on a SX3100?
   / Rear Ballast SX3100 #2
Your rear lift is rated for 1209 lb. per tractordata.com
If you just need some rear ballast for doing loader work 400-600 lb. should work very well.
   / Rear Ballast SX3100 #3
I like to balance the loader capacity with the rear ballast. My lx4900 lifts 2500, I have rear tires loaded which adds 1100, and have a 1500 lb box blade. Loading the rear tires really helps, and is always there.
   / Rear Ballast SX3100 #4
I have loaded tires and I hook up my box blade when I so loader work. It is only a 4' blade and weighs about 250 pounds. It works good unless I have a full bucket of dirt and have to go down hill. The rear tires get a little lite for my taste. I have also strapped 4 cement blocks on my blade and it makes it much safer. So with loaded tires I would say at least 400# and you should be good.
Sent from my iPhone using TractorByNet
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
1982 MACK RD685S HOTOILER (A52472)
1982 MACK RD685S...
