Backhoe rear backhoe throttle control mod Mt122 /mt125 backhoe
   / rear backhoe throttle control mod Mt122 /mt125 backhoe #1
nslstractor
LS mt122
With the Mt 122 being so small I can easily reach the steering wheel while at the reverse backhoe position. I thought I could get more done if I could reach the hydrostatic peddles.
Turns out the 2 peddles each link to a single push pull Control so I threw together some very quick linkage and it works great.
I can use my backhoe and thumb to move things around and easily make small adjustments while digging without moving the seat around.
Https://imgur.com/a/y3n9P9O
Here was my inspiration, one of the few reverse driving backhoe videos I could find.
Https://youtu.be/Z1uzuwwPVt4
Let me know what you think.
Leave it in Neutral with the brake off. Use the outriggers and FEL as a brake. Raise all three a few inches and use the BH bucket to push or pull you.
That works pretty good for trenching but this let's me empty my bucket further than 6 feet away from my dig easily. Also I was able to move some logs around the yard using the hoe /thumb as a sort of grapple alternative.
   / rear backhoe throttle control mod Mt122 /mt125 backhoe #4
You're links don't work either. :laughing:
But welcome to the forum!
:welcome:
:welcome:
Ty,
The forum said I had not made enough posts to add links... Just remove the word "link" and it should work
17101 (A55787)
17101 (A55787)
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
Kubota L3130 (A53317)
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
Electric Utility Cart (A56857)
Electric Utility...
