Backhoe rear backhoe throttle control mod Mt122 /mt125 backhoe
   / rear backhoe throttle control mod Mt122 /mt125 backhoe #1
nslstractor
LS mt122
With the Mt 122 being so small I can easily reach the steering wheel while at the reverse backhoe position. I thought I could get more done if I could reach the hydrostatic peddles.
Turns out the 2 peddles each link to a single push pull Control so I threw together some very quick linkage and it works great.
I can use my backhoe and thumb to move things around and easily make small adjustments while digging without moving the seat around.
Https://imgur.com/a/y3n9P9O
Here was my inspiration, one of the few reverse driving backhoe videos I could find.
Https://youtu.be/Z1uzuwwPVt4
Let me know what you think.
Leave it in Neutral with the brake off. Use the outriggers and FEL as a brake. Raise all three a few inches and use the BH bucket to push or pull you.
That works pretty good for trenching but this let's me empty my bucket further than 6 feet away from my dig easily. Also I was able to move some logs around the yard using the hoe /thumb as a sort of grapple alternative.
   / rear backhoe throttle control mod Mt122 /mt125 backhoe #4
You're links don't work either. :laughing:
But welcome to the forum!
:welcome:
:welcome:
Ty,
The forum said I had not made enough posts to add links... Just remove the word "link" and it should work
2020 FABRIQUE H9618TRTV-100 18FT ENCLOSED TRAILER (A51222)
2020 FABRIQUE...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
Case IH 8610 Tub Grinder (A50514)
Case IH 8610 Tub...
2021 TAKEUCHI TL8R2 SKID STEER (A51242)
2021 TAKEUCHI...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
