Rear Axle Spacer Kit?
   / Rear Axle Spacer Kit? #1
Country1
Virginia, The "Old Dominion"
Kubota M7060 HD12
Anyone know what a Kubota "Rear Axle Spacer Kit" consists of? How much rear width do you gain? I saw this in the "build your own" section for the M40 series tractors. It was under dealer add-on options and was priced at around $500. I did a search, but didn't come up with anything...
   / Rear Axle Spacer Kit? #2
Interesting, I never noticed this. We mow on some really steep stuff though with our M8540 and it is extremely stable, so we don't need anything wider.
That's one thing I noticed between the M7040 and the M8540/M9540 is the rear wheel spacing. I know they're a larger framed machine, but the cab height is the same as the M7040. The narrow stance of the tractor has me a little worried even set to the widest possible adjustment. When comparing the two, it looks like the "rear axle" (for lack of a better word) is just plain wider on the M8540.
Your's looks to be set as wide as possible and looks like it would be pretty stable. The M7040, not so much... Wonder how wide the spacer kit is??..
   / Rear Axle Spacer Kit? #4
I would have to check to make sure, but I think ours will go one step wider, but the salesman said he thought the next widest would be enough and it has been.
I knew the M85/9540 were a little different, but I didn't look too closely at the 7040 to notice they were narrower.
I agree, you want wide stance on slopes. Even though I know our tractor is stable there are places that raise my pucker factor to an intolerable level.
I would sure check the axle space kit. Have you gotten any feedback from Builder? He does custom bush hogging with his M7040 cab pulling a JD MX8 and a flail I think.
Yeah, it just so happened that they had three M7040's and then a 85 and 95 all lined up in a nice row. You could really see the difference and the M7040 next to the M8540 had the rears set as wide as possible.
It will probably be fine set on the widest setting, but I'd like more info on the spacer kit since it is an option. If it adds 1.5" to each side, I think it would be ideal....
I'll check with Builder or maybe shoot Barlow and email. Thanks Triple.
   / Rear Axle Spacer Kit? #6
It probably will be stable enough, but I sure would check into the spacers.
I just saw this thread and can see the difference in width.
Turning orange - Page 2 - TractorByNet.com
I got a quick email back from Brady Barlow and he says it makes the rear tread 72". Online spec says 52"- 67.7", so I figure each spacer adds 2.15".....
I'll talk in greater depth with him when I get closer to ordering.
   / Rear Axle Spacer Kit? #8
How does that compare with the M8540/9540?
What tires are you getting?
The M8540/9540 spec says 59.8" - 75.6". So 3.6" less on the widest setting. The other thing I figured out is the spec is center tread to center tread.
The only size they offer in R1's is 16.9-30 with cast wheel.
Pic of M7040 with rear space set one setting in from widest.
Looks like it would be a little tippy to me...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2022 Toro 21in Hydraulic Walk-Behind Turf Aerator (A52377)
2022 Toro 21in...
Genie GTH-644 (A50490)
2019 Ford F-150 Crew Cab 4X4 Pickup Truck (A53422)
2019 Ford F-150...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
