Rear Axle Seal Housing
   / Rear Axle Seal Housing #1
roy weidner
Thomasville Ga
Yanmar 1500
Broke this bolt on piece to a Yanmar 1500 Red . Can I simply pull the rear wheel and replace?
   / Rear Axle Seal Housing #2
What???
I dont understand your question? Did you brake the bolt that holds the hub on? IF you have a broken bolt your going to have to get the bolt out of where its broken.
I think we need pictures here for this one.
   / Rear Axle Seal Housing #4
Winston I'm betting its #35 he broke. I'm curious what he was trying to fix when it broke.
   / Rear Axle Seal Housing #5
That would be my guess too. Maybe trying to tighten it up to stop a leak? :confused3:
   / Rear Axle Seal Housing #6
If its a leak there he has more problems. That's a dry housing.
The bolt on piece #33 broke on the left side and the top bolts #35 broke both left and right sides
   / Rear Axle Seal Housing #8
No, it broke becasue there was a makeshift roof attached to the fender. The fender bolted to the top two bolts of the seal housing. The driver got the roof caught up in a limb that tore the roof off. Breaking the bolts holding the roof on and breaking the top half of the seal housing.
   / Rear Axle Seal Housing #10
Ah ok. You will need to remove the hub. # 28 in the axle internals picture. It's held on by the one bolt. I needed to use a puller to get mine off. Then you can replace the broken housing and the seal. It's a dry axle but there is a seal there to keep out dirt. You may find you also need the sleeve the seal rides on too. Also there's a paper gasket. Some sealant there would be fine.
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
40' shipping container (A52377)
40' shipping...
2012 GREAT DANE 53FT REEFER TRAILER (A53426)
2012 GREAT DANE...
CHAMPION 1 PERSON GAS EARTH AUGER (A51248)
CHAMPION 1 PERSON...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2015 CATERPILLAR...
2023 UNVERFERTH 632 LOT IDENTIFIER 146 (A53084)
2023 UNVERFERTH...
