Rear Axle Seal Housing
   / Rear Axle Seal Housing #1
roy weidner
Thomasville Ga
Yanmar 1500
Broke this bolt on piece to a Yanmar 1500 Red . Can I simply pull the rear wheel and replace?
   / Rear Axle Seal Housing #2
What???
I dont understand your question? Did you brake the bolt that holds the hub on? IF you have a broken bolt your going to have to get the bolt out of where its broken.
I think we need pictures here for this one.
   / Rear Axle Seal Housing #4
Winston I'm betting its #35 he broke. I'm curious what he was trying to fix when it broke.
   / Rear Axle Seal Housing #5
That would be my guess too. Maybe trying to tighten it up to stop a leak? :confused3:
   / Rear Axle Seal Housing #6
If its a leak there he has more problems. That's a dry housing.
The bolt on piece #33 broke on the left side and the top bolts #35 broke both left and right sides
   / Rear Axle Seal Housing #8
No, it broke becasue there was a makeshift roof attached to the fender. The fender bolted to the top two bolts of the seal housing. The driver got the roof caught up in a limb that tore the roof off. Breaking the bolts holding the roof on and breaking the top half of the seal housing.
   / Rear Axle Seal Housing #10
Ah ok. You will need to remove the hub. # 28 in the axle internals picture. It's held on by the one bolt. I needed to use a puller to get mine off. Then you can replace the broken housing and the seal. It's a dry axle but there is a seal there to keep out dirt. You may find you also need the sleeve the seal rides on too. Also there's a paper gasket. Some sealant there would be fine.
2002 CATERPILLAR 973C CRAWLER LOADER (A51246)
2002 CATERPILLAR...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
UNUSED CFG INDUSTRIAL NT18K EXCAVATOR (A51247)
UNUSED CFG...
2000 HONDA RANCHER 350 ATV (A51247)
2000 HONDA RANCHER...
