Rear Axle on 1500D Hub removal
   / Rear Axle on 1500D Hub removal #1
klawson44
Virginia
I am trying to get the hubs off of the rear axles on my 1500D, I have a puller on it and am soaking it with penetrating oil, it aint budging. I do not want to use heat on the cast hubs, is there a secret?? I need to replace the bearings and seals. Thanks for any advice you guys may have....
   / Rear Axle on 1500D Hub removal #2
I think most guys do use heat on the hub, also a few well aimed blows with a large hammer on the bolt of the puller helps. "PB Blaster" is generally considered the most efective penetrating oil. I have heard that you can put the wheels back on, leave the hub bolt loose and drive the tractor around, lots of quick starts , stops and turns, and they will sometimes loosen. Last resort is to go in through the rear end and remove the axles.
   / Rear Axle on 1500D Hub removal #3
I think you will have to remove the axles anyway to replace the bearings, but I'm not sure it will be any easier to remove the hubs with the axles off the tractor.
As I remember, when I pulled mine a while back there was grease on the splines. That made it easy to remove. I made sure they were greased when I reassembled it.
You might want to ensure the inner seals and collars are good. That might save you the hassle of taking it apart again.
Good luck.
   / Rear Axle on 1500D Hub removal #4
These can be tough. If a little heat and a puller, some tapping with a hammer, etc doesn't do it, then I would recommend pulling the axle and using a shop press. I had a set of hubs stuck really badly on a 1401 once and I apllied too much force and too much heat and ended up getting them off, but damaging the hubs. I had a spare set, but I really should have pulled the axles and pressed them out.
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
2006 UNKNOWN 16 T/A TRASH TRAILER (A52472)
2006 UNKNOWN 16...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53472)
John Deere 5090E...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
