Rear axle broke on my 2016 XJ2025h with 245 hours
   / Rear axle broke on my 2016 XJ2025h with 245 hours #1
sbct
Penryn, CA
LS XJ2025H
Tried using my box blade the other day and noticed my XJ2025h felt like it had no power. Shifted out of 4wd and into 2wd and hit the forward pedal and the tractor wouldn't move. No power to the rear wheels. If I pushed down on the diff lock then hit the forward pedal the tractor would slowly move with a horrible grinding noise coming from the rear end. Let off the diff lock pedal and back to no power going to the rear wheels. I was able to put it back in 4wd and use the front wheel drive to get her up on the trailer and off to the dealer she went.
Hydraulic fluid was full and looked good. Dealer thinks rear axle let go based on the story. Rear pto still engages and works fine, just no power to rear wheels!
Soonest they said they could try and look at it is Tuesday.
Anyone have any ideas?
   / Rear axle broke on my 2016 XJ2025h with 245 hours #2
Sounds like a definite failure somewhere in the rear end. The main reason for failure that I have seen is if the diff lock doesn't release and you make turns on a hard surface. At 4 years old it should be covered by warranty.
   / Rear axle broke on my 2016 XJ2025h with 245 hours #3
Sounds like the differential let go. Using the diff lock on hard surfaces is extremely hard on it.
My BIL did that to an old JD backhoe. Repair estimate at the dealer was $10k.
   / Rear axle broke on my 2016 XJ2025h with 245 hours #4
OUCH..........
I never use the diff lock really and only ever drive on dirt so I'm thinking just maybe some bad luck? Still have a year left on my warranty so hopefully whatever they figure out is broken gets taken care of by LS. 107 miles each way to the dealer is the true inconvenience! 5 hours round trip if you count loading and unloading and maybe a coffee stop along the way. Then gonna be another 5 hour round trip when she's ready to come back home. A real good group of guys though that work at this dealer so I'm confident they will get her fixed up!
   / Rear axle broke on my 2016 XJ2025h with 245 hours #7
Axle or differential side gear, I shattered on in my 57 Bel-Aire back in my teenage hot rodding days.
Dealer confirmed busted axle. Waiting for parts to be shipped from North Carolina to California.
   / Rear axle broke on my 2016 XJ2025h with 245 hours #9
it sucks if this is supposed to happen!..
   / Rear axle broke on my 2016 XJ2025h with 245 hours #10
I'm glad the dealer found the problem and that warranty will cover it.
SORKO MC19-10 LOT NUMBER 149 (A53084)
SORKO MC19-10 LOT...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
2006 CHEVROLET EXPRESS CUTAWAY BOX TRUCK (A52577)
2006 CHEVROLET...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
Mini Skid Steer Sweeper Attachment (A51573)
Mini Skid Steer...
