rear arms wont lift or lower
   / rear arms wont lift or lower #1
jcarlile
nipomo
iseki tu2100
I want to use a box scraper but rear controls do not raise or lower the arms. I've turned the valve, still nothing. I bought this iseki tu 2100, took it apart to replaced front trans cover and got it back together works great just need to be able to use the back arms for implements.
What do I check or take apart?
figured it out front in loader hydraulic lines we're out of order fixed
   / rear arms wont lift or lower #3
Glad that you were able to get it fixed! What was the issue with the hydraulic lines?
i didn't have the hydro lines on the manifold for the front end loader correct. switched them and all works perfect. i bought the tractor with a hole in the trans cover, located the part, broke the tractor in half, repaired it, but the loader came separate so i was guessing on the line connecting. im good with auto so i felt good about tackling this project, plus it was the cheapest way to go for myself. all is well it runs like a champ and now with the box scraper on back i'm not getting stuck in the sandy ground i have.
Enclosed Trailer (A52377)
Enclosed Trailer...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
JOHN DEERE 54D LOT IDENTIFIER 149 (A53084)
JOHN DEERE 54D LOT...
UNUSED FUTURE HYD WOOD DRILL (A51248)
UNUSED FUTURE HYD...
TROYBILT TB51BP GAS BACKPACK BLOWER (A51248)
TROYBILT TB51BP...
BUSH HOG 7007 LOT IDENTIFIER 104 (A53084)
BUSH HOG 7007 LOT...
