Backhoe Rear arms do not work with backhoe attached
   / Rear arms do not work with backhoe attached #1
meb9796
VA
JD 3720
I purchased a used backhoe 2 years ago and tore it apart and rebuilt it. I installed a power beyond system on my 3720 about a year ago and it's working fine (ie, I can use the rear arms and loader, etc, just fine). Tonight I connected the backhoe for the first time and filled the tractor with hydraulic fluid as I moved each arm of the backhoe to get it ready to connect to the tractor. Since it wasn't connected, I couldn't really move the arms that much, but each arm is moving fine and I can move the loader while the backhoe is attached, but I can't lift the rear lift arms? They will go down, but will not go back up until I remove the backhoe and reattach the power beyond system. I know that John deere backhoes (this is an ameriequip backhoe that is a 3pt connection) connect to the subframe and you don't need the rear arms, but I know that the power beyond can control a lot more than a backhoe so the rear lift arms have to be able to work while using the power beyond system.
I monitored the hydraulic fluid while working with the backhoe and added over 3 gallons and I know it's a bit low. But when I disconnected the backhoe, the lift arms worked? Anyone have any ideas???
thanks!
I purchased a used backhoe 2 years ago and tore it apart and rebuilt it. I installed a power beyond system on my 3720 about a year ago and it's working fine (ie, I can use the rear arms and loader, etc, just fine). Tonight I connected the backhoe for the first time and filled the tractor with hydraulic fluid as I moved each arm of the backhoe to get it ready to connect to the tractor. Since it wasn't connected, I couldn't really move the arms that much, but each arm is moving fine and I can move the loader while the backhoe is attached, but I can't lift the rear lift arms? They will go down, but will not go back up until I remove the backhoe and reattach the power beyond system. I know that John deere backhoes (this is an ameriequip backhoe that is a 3pt connection) connect to the subframe and you don't need the rear arms, but I know that the power beyond can control a lot more than a backhoe so the rear lift arms have to be able to work while using the power beyond system. I monitored the hydraulic fluid while working with the backhoe and added over 3 gallons and I know it's a bit low. But when I disconnected the backhoe, the lift arms worked? Anyone have any ideas??? thanks!
Moved to hydraulic section!
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
2019 Ford Fiesta SE Hatchback (A55853)
2019 Ford Fiesta...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE MINI...
2012 Infiniti QX56 SUV (A55853)
2012 Infiniti QX56...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
