Rear 7 pole connector
   / Rear 7 pole connector #11
My tractor came with the 7 pin connector shown above, I removed that one and replaced it with a 7 pin flat just like what comes on a factory wired truck. That way anything I use behind my truck will also work behind my tractor. Granted unless I install a break box the electric breaks won't work but if I need those I will deal with it then. The only thing I use the plug now is so I can plug in the electric pump on my fuel storage tank to fill the tractor, and with the same plug as the truck I could even plug into the truck if needed.
I wanted to post an update with regards to the installation of the rear 7 pole connector.
After looking around at the rear wiring harness, the wiring harness already had a female connector that would allow the addition of a male connector. I called two LS dealers to get an idea of the connector that would be needed and neither of the dealers knew anything about it. I then decided to call the LS factory in NC and after speaking with someone that was supposed to know about the connection- I was told that the connector is a standard connector that is used on all trailers.
I went down the road to the local trailer repair shop and showed them a photo of the female connector found on the wiring harness of the tractor. Not a connector that they use but was told that an automotive shop would be the best bet. They thought that the connector was something that is used in automotive wiring harnesses.
Next trip was to a NAPA distribution center- of course, they had no clue as to the connector.
Onward to an internet search on wiring harness connectors..... found a wiring harness company that did identify the connector and could send a male connector with 6 inch wires for $128.
So, Looking online some more and comparing the female connector to what I thought would mate with, I came across MX150 connectors. I ordered some wireless connectors off of ebay for $6. Once they arrived, they plugged perfectly into the female connector. Sure, I had to plug in each male connector into each of the female connections, but for the cost, I can live with that.
Here is a picture of the finished 7 pole connector within it's blue plastic electrical box.
I had to run to another tractor shop for something else to buy and saw that they had LS tractors with the 7 pole connectors already installed. They did have connectors for $38 (without the 7 pole setup). Here is the factory installed version as well.
   / Rear 7 pole connector #13
All that running around and trying to find it is exactly why I went to walmart and got a flat pin connector I just took the male end off of the factory plug and installed it on the new plug. I did find them on the internet but I didn't want to wait for one to come in.
Yes, the fun of trying to connect directly into the one that existed on the wiring harness. One would think that the calls to the LS dealers and factory would have taken care of , but guess not.
2019 BOBCAT T590 SKID STEER (A52709)
2019 BOBCAT T590...
8 sets of Jumper Cables (New/Unused) (A59225)
8 sets of Jumper...
1998 Homemade S/A 12x6.5ft Trailer (A56859)
1998 Homemade S/A...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
PALADIN INDUSTRIAL SCREENER (A58214)
PALADIN INDUSTRIAL...
