rear 3pt arms drop overnight?
   / rear 3pt arms drop overnight? #11
On both my Kubota's, I can lock the 3ph in the up position by closing the needle valve that controls the speed of drop when an implement on the back end. I rarely do it however. Like I said previously, not germane to operation at all.
   / rear 3pt arms drop overnight? #12
I once owned a Branson 3510i that leaked and dropped slowly, so we changed the seals on the rear piston and presto, it was the cure.
   / rear 3pt arms drop overnight? #13
My loader will drop and curl down if setting for an extended time. My three point will stay up forever, even with a load. However if it dropped after setting all night, I wouldn't be overly concerned. My old Ferguson has done that for the last 60 years.
Same with my old MF 135. The 2018 Kubota will seemingly stay up forever even with a load. Not concerned with either but try to drop both when I dismount.
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
