Reapir to Hydraulic Ram (weld)
   / Reapir to Hydraulic Ram (weld) #1
HankStains
Berry, France
Fordson Super Major, Massey 835-DS, Energic 521, John Deere 420, Case 580B CK
Hi guys, looking for some advice. The stubby ram (1 of 2)which controls the slew on my backhoe has broken. The nut which is screwed onto the end of the ram part has snapped off.
Should I drill and tap or try and weld the nut and threaded part back on. The ram shows about 1/8" of bare steel before the nickel plate starts. it is a 30mm ram and only about 1' long. If I weld will I ruin the seal. If I thread, what size and pitch should I use. I can take the ram out with out any problems..
Does anyone know how much i could expect to pay for a replacement piston???
thanks for your help
Pete
   / Reapir to Hydraulic Ram (weld) #2
I'd bring it to a hydraulics shop and get a quote. I've cut and welded rams before, but it seems to me drilling and taping may not work (or would break) as would likely a weld.
A hydraulics shop could probably just replace the broken piece.
   / Reapir to Hydraulic Ram (weld) #3
I used to work as a weldor and machinist in a hydraulics shop and we welded the bushings and rams together with a 7018 or 90 18 which ever one was there. n AC Id use a 6013 or 7014 But SDC usr the 70 or 9018. I have a small machine shop here and do alot of cylinder repairs andcustom cylinder fab. When I weld a ram to a bushing or sleeve Ill center drill it in the lathe and dowel pin itto old postions. Then i put vaseline on the rams chrome to protect it from spatter. I usually ground off the bushing to make sure I dont smomake a seal acking or andother damage.
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2008 FORD F750 SUPER DUTY BUCKET UTILITY TRUCK (A50854)
2008 FORD F750...
