Reaming out holes in thick steel?
   / Reaming out holes in thick steel? #91
I like this TBN forum. Lots of good input, not much b.s., most of the time.
It is a great forum, even the BS is good some of the time...
   / Reaming out holes in thick steel? #92
I want to enlarge four 13/16" holes in 1/2" thick steel to accept 7/8" pins. This on a piece of equipment so I have to use a hand drill. I happened to have a 15/16" black oxide bit, not too surprisingly that doesn't work at all. In 10 minutes I only penetrated about 1/8" in one hole. So I need to decide between buying an $80 construction reamer (high speed steel, manufacturer says it is OK for stainless) or pick up a 29/32" cobalt drill for under $50. I'm guessing the reamer would work better even though it is softer. Is that correct?
pneumatic die grinder with a diamond cut bit would take care of it as well. Just be aware it will probably want run around in circles in the hole so go slowly.
   / Reaming out holes in thick steel? #93
Use a torch or a die grinder. Be done in a few minutes. Pick one up at a pawn shop. You're welcome.
   / Reaming out holes in thick steel? #94
So many good options/aspects mentioned here. (y) If grinding or filing I might trace a target outline to rough the opening. Holding any power tool steady/firmly is paramount. Lube oils are poor cutting fluids unless 'hogging' and 'flooded'. Use bacon grease or pork drippings liberally with power tools in a pinch. Your chip will always tell you if you're going slow enough, using enough pressure, and/or cutting efficiently w/o dulling the tool before you're finished.
My top choices are a bridge reamer, step bit to its max OD & w/coolant, or piloting/stacking hole saws. If you break the corners of a conventional drill bit do so sparingly. IMO, metal is likely low carbon steel and wouldn't work-harden. btw, if you get 2-4 holes before your cutter is toast you did good. It's being hand work that makes it so.
   / Reaming out holes in thick steel? #95
Good point about the work hardening.
   / Reaming out holes in thick steel? #96
a pointed burr should be helpful and you can use it with a lessor powered drill so if it catches you won't get hurt good luck ron
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
2018 RoGator 1100C (A46884)
2018 RoGator 1100C...
AGT Mini Excavator (A47809)
AGT Mini Excavator...
2025 Swict 84in Bucket Skid Steer Attachment (A46683)
2025 Swict 84in...
2006 SAND SEPARATOR (A47001)
2006 SAND...
(3) VACUUM PUMP TANKS (A47001)
(3) VACUUM PUMP...
