Really Weird Tire Losing Air Issue
   / Really Weird Tire Losing Air Issue #1
RWEST
Windber, PA
ALL J-D's: 955, X595, 6x4 Diesel Gator, CX Compact Gator, 310D Loader/Backhoe (4x4, turbo, extend-a-hoe)
Here's one that is driving me about out of my mind!! :confused: The rear tires on my J-D 955 are partially liquid filled. If I park the tractor with the valve stem of the left rear tire anywhere below the horizontal plane (using the clock face analogy - from 3 to 9), the tire will lose fluid/air, and go flat if it sits for a day or two. You can see where a small bit of fluid leaks out around the stem, but, all the air is gone. So, I have to drag extension cords and my little compressor from the house to the garage and pump it up. If the stem is above horizontal, everything is fine - it can sit for a month or more, no problems. It doesn't make any sense. Air molecules are smaller than fluid, right? If the stem's bad, the air should leak out regardless of where the stem is located, wouldn't you think? Please help!! :confused:
   / Really Weird Tire Losing Air Issue #2
I'd look for something stuck in the tire -- like a nail or screw or thorn - that is on the opposite side. ie: if the tire is sitting so that the puncture is on the bottom - it doesn't leak - if it's on top - it does. or -- something in the bead - same scenario (I get tree bark stuck in the bead sometimes-- you can guess how)
   / Really Weird Tire Losing Air Issue #3
Sounds like the weight of the tractor pinches teh hole shut when it is on the bottom but allows it to leak when on top. Add about 3psi more air than required and use soapy water on tire with the suspect hole at the top. See what bubbles up.
   / Really Weird Tire Losing Air Issue #4
Jack the axle up to take the weight off the tire and pull the stem out. I just replaced the stem on my TN as it was doing the same thing. The little o-ring on my stem started to give up for some reason as it would lose air slowly. Just take the weight off the tire first otherwise the fluid will be forced out of the valve body when you pull the stem (if your fluid is that high to begin with).
   / Really Weird Tire Losing Air Issue #5
There are professionals that know how to handle that type of thing.
   / Really Weird Tire Losing Air Issue #6
A few of us amatures can deal with it too......
Robert was right. Jack the wheel up off the ground. Put valve stem @12 :00 high. Unscrew core of "schraeder valve". Put new core in. Air to correct pressure. Go tractorin'!
They just go bad every now and then. Reason #79,351 why to NOT use cal/chlor in tractor tires if you don't like rust.
   / Really Weird Tire Losing Air Issue #7
Professionals; We don't need no stinkin professionals. :)
   / Really Weird Tire Losing Air Issue #8
Expert, Ex=has been spurt=drip under pressure
   / Really Weird Tire Losing Air Issue #9
That fluid that seeps out--
It is CALCIUM, and if it gets between the liner and the rim you will be buying a new and possibly very costly rim.
Don't ask how I know.
My little Mitsubishi front rim was quoted at $450.00!
Rinse off that rim thoroughly
   / Really Weird Tire Losing Air Issue #10
Nothing inherantly wrong with CACL.. It's about the cheapest, easiest weight you can add.
Just have to do a bit of maintenance.
#1,, start with clean painted rims.
#2, start with a new tube.. not an old leaky one from 1957.
#3, When you notice corrosion around the valve stem.. start thinking about a new tube. I generally try to force some oil or grease down the core/stem of my tubes with fluid. That small film barrier makes a huge difference.
soundguy
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52576)
2023 TAKE 3...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A51573)
New/Unused AGT...
2016 MACK CXU613 SLEEPER TRUCK (A52576)
2016 MACK CXU613...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
