Really dislike Robin Subaru engines
   / Really dislike Robin Subaru engines #31
For what its worth, I think we (the Power Trac forum at large) calculated the theoretical potential HP at the main PTO of a PT425 at something a tad less than 14HP. You should think about Raw Dodge's comments about fluctuations and what you'd get out of the PTO on the Power Trac. From my own generator, it has a governor. When the load is high, it opens the throttle to boost the gas, to maintain the known RPM that will generate 120V. There's no meter or electronics that control the engine speed. Its just a set throttle of either OFF or ON at about 3600RPM set at the factory. Your Ventrac generator is belt driven, correct? How do you set the engine RPM for proper voltage? Is there a voltage meter and you increase the throttle until you get your 120V and the engine just holds there? I'd suspect if you drove it off of the PT's hydraulics, you'd just do the same thing. Since a fluid is not compressible and belts can slip, I'd think you'd get more consistent power with hydraulics than belts. But you're going to get substantial HP loss of available power from the hydraulics VS the belt. The 13,000 watt generators I've seen recently are running 20+HP engines and those are direct drive. You'll never get that out of the PT425 hydraulic PTO. Using the calculator at this website and plugging in the rated PT425 main PTO pump pressure of 2500PSI and flow of 8GPM you get about 14HP Hydraulic Calculations | Fluid Power | Advanced Fluid Systems (2500PSI X 8GPM) / (1714 X 85%) = 13.73HP For more on what the 1714 is and why 85% efficiency.... OUCH, my brain hurts! :laughing: 1 horse power = 33000 foot-pounds per minute (by definition) 1 US gallon = 231 cubic inch (by definition) 1 psi = 1 pound per square inch (by definition) In the equation HP=kΔPF where F = flow rate in gallons per minute, ΔP is pressure difference in psi, and HP is power in HP, you need a conversion factor. Doing everything in inches: HP33000∗12∗inch−pounds/min=kΔPpounds/in2flow231inch3/min from which it follows that k=23133000∗12≈11714 In other words, "in plain English that a 9th grader can understand, and yet be correct and true to its purpose and place in life to satisfy seasoned physicists": 1714 represents the numerical scale factor needed to obtain pump power in HP given pressure in units of psi and flow rate in gallons per minute. It is not an exact number - only approximate."
I'm not sure about how much experience you have with working with small hydraulic systems and belt drives,but I can tell you that I own a ventrac,and I have about 15 hydraulic drive mowers and equipment at the golf course..I've been the mechanic and operator there 24 yrs. About the ventrac drive system,the belts do not slip period...if they slip which mine never have its because the belt has oil on it or is ready to fail...They use B series belts on a large 7inch diameter drive pulley,with an automatic tensioner,and a 75 hp rated electric clutch...the rpm will not move more than 50-100 rpm from full load to no load,the engines governor is the same exact one used on those same engines installed in gensets....the efficiency of the belt drive is about 85-90 percent with this system...a hydraulic motor hooked to a small machine working at its maximum rpm and gpm will run around 55 percent efficiency,hence the need for a hydraulic cooler, a lot of power is wasted and turned into heat thru pressurization,restriction, and leakage.As. the pumps and motors wear,the performance starts to drop,and leakage around the pump and motors vanes,and plungers increase,and the speeds will drop as loads increase where as a belt drive will not. In order to have an honest 12 hp at the hydraulic motor you will need about 20 horsepower driving it and still not have quite the rpm control a belt drive only needing a 15 hp engine will... Our older mowers hydraulic drive reels and blades do slow down slightly in heavy growth and especially when used on a hot summer day,where as our older belt drive machines do not have the same issues,just keep the belts tight and in alignment and no rpm loss .I like the reliability of a hydraulic drive ,personally ,even though it's more expensive up front and to repair,no belt failure issues and belt alignment problems...but there is no arguing that a properly designed belt drive will put out more power with less rpm change and way more efficiency..
   / Really dislike Robin Subaru engines #32
I have a Subaru robin engine. It's been real good for me.
2021 Ford F-250 4X4 Crew Cab Pickup Truck (A55973)
2021 Ford F-250...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
New/Unused IRGC40 Mini Golf Cart (A57453)
New/Unused IRGC40...
flooring (A55758)
flooring (A55758)
