Loader Real world fork capacity on B and BX series
   / Real world fork capacity on B and BX series #11
My L3200 was REALLY sketchy lifting "1,200lbs" big square bales on pallet forks. I could only hit 4' high or so I'm most bales. I also had a couple hundred lbs of stuff stacked on the very back of the rotary cutter (lots of leverage back there) & the back end was very light & sketchy.
No way a much smaller machine will be lifting & moving 1,000lbs on the loader. Good chance if you had 3pt forks though. And a safe failure mode (front end comes up) instead of the loader failure mode (front axle breaks or more likely you lift the rears, balance on the front axle which promptly pivots & you roll the machine).
   / Real world fork capacity on B and BX series #12
It may not be the hydraulics that limit you rather the front axle/front end wear and tear.
   / Real world fork capacity on B and BX series #13
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
(2) 5' TRAILER RAMPS (A57192)
(2) 5' TRAILER...
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
UNUSED FUTURE HYD 12" AUGUER (A57193)
UNUSED FUTURE HYD...
(2) USED 700 LB TRAILER BRAKE AXLES (A57192)
(2) USED 700 LB...
