Ready to buy ?
   / Ready to buy ? #1
Beavis
Kansas
JD 4720
First and foremost, let me say thanks for such an informative webiste and all of those who take the time to share their knowledge and experience with others.
I am shopping for a new tractor, looking close at the JD brand, especially the 3320. I've looked at a lot so far and our State Fair is Sept. 7-16th which should give me a good chance to look at several models side-by-side. My purchase should take place shortly after that.
One Question: I had been looking at the Mahindra 3215HST, which is turbocharged. What are some general thoughts about a turbo vs. a non-turbo: engine life, maintenance, expense, etc.
THANKS
   / Ready to buy ? #2
Turbos for diesels are very well proven and in wide use. Unless you're at high altitude (and I assume you aren't in Kansas) the turbo/non turbo issue is of little importance compared to the rated PTO hp and fuel consumption. No significant maintenance difference for a turbo. The turbo will eventually fail and need to be replaced for significant money, but that should be many years down the road (errr, crop row).
   / Ready to buy ? #3
I've looked at the JD 3320, nice tractor, very good looking machine, comfortable, good power, nice size tires, good lifting ability. Almost bought it, but dealer told me it was too heavy for all the mowing I do and advised me to get a Kubota B3030, I was looking for something with a cab.
From reading the posts the Mahindra's seem to be very reliable and appear to be lower in cost per HP. But, I'm a traditionalist, and trust the tried and true, make mine green, orange, or blue.
   / Ready to buy ? #4
Beavis -- welcome aboard! It soundsl like you have been around long enough to know a lot of us look at the dealership as being at least half of the decision. When I was shopping, I looked at Mahindra and almost everything else. Mahindra was in the running 'til the end. I decided to go with Case. The Mahindra dealer is now gone. Both the Case dealers are still doing business where they've been for upwards of 40 years. JD is still here, has branched out to 3 locations now. NH is equally well represented.
The Case dealers also carry Kubota and Cadet, but their big machinery is Case, and I suspect it's also a large part of their business success.
I'm not knocking Mahindra, they look like good machines. I just encourage you to look at the dealership from the standpoint of local history, personnel, service, etc. It sounds like that could be your deciding factor.
For mowing, Mahindra's would be lower down my list due to their weight, and Kubota's would be high up for the same reason. One is heavy, the other light.
   / Ready to buy ? #5
Beavis,
roughly where in Ks are you?
Mahindra has dealers in Wichita, Marian, Hutch, and by KC for the Eastern half of the state. Not sure what they've got in the Western half.
When I was shopping I looked at the 2810, 4110, and 3215 and all were comfortable, but economics kicked in so I ended up with something else.
Good plan waiting for the fair so you can sit in a bunch of different seats on the same day.
Happy shopping!
   / Ready to buy ? #6
DaTeacher... Funny thing for Beavis is that the Mahindra dealer and the Case dealer are most likely the same for him.
   / Ready to buy ?
Was down in Hutchinson Kansas today for "set-up" at the fair. I had a chance to look at Kioti, Kubota, JD, and Mahindra. I think I'd be happy with any of these tractors; now it is time to see who is willing to make the BEST DEAL. Any last minute input would be appreciated, I think I've thought about most things but I'm open to anything new. ( for example, the Mahindra dealer told me about a 10 year warranty for only $299 )
   / Ready to buy ? #8
HI BEAVIS, WELCOME TO THE FORUM ! you don't mention what you want to do with the tractor or how much land you are going to use it on. Might be helpful to help you make a decesion.
   / Ready to buy ?
I've got 24 acres with no trees (yet) and the plan is: build a metal building this winter, followed by a house next year. There will be two driveways, each being approximately 400ft. long. (blade for gravel spreading and snow plowing) I will use the loader for landscaping projects throughout the entire building process. There are some terraces that I will want to flatten out (blade and loader) and MAYBE build a pond in the years to come. I have a dirtbike and may want to play with building a mild motorcross track. (loader) My father-in-law has a Ingersoll 6018 ( 2wd, 18hp gas powered, hydrostat tractor) that I have used for minor landscaping projects at our current house, but it is WAY TOO SMALL for the stuff I have in mind. It is still up in the air wether I will purchase a finishing mower to pull behind or purchase seperately a Hustler Super Z.
   / Ready to buy ? #10
On your question on turbos. They are fine. Great in fact at making gobs of reliable diesel HP. One thing you MUST DO, idle the tractor for 1-5 minutes before shut down to allow the turbo housing to cool off. Personally, I would add an EGT gauge between the exhaust manifold and the turbo housing so you can monitor the temps. 1300-1400 is the high safe range. 1600 for long and you will damage / melt stuff that you don't want to have to pay for.
jb
Pull-Behind Rotary Brush Cutter PTO Attachment (A51691)
Pull-Behind Rotary...
2013 Yamaha YDREx4 Electric Golf Cart (A51691)
2013 Yamaha YDREx4...
JOHN DEERE WHP48A LOT NUMBER 97 (A53084)
JOHN DEERE WHP48A...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
UNUSED FUTURE SSJ430J WALK BESIDE JAW CRUSHER (A51247)
UNUSED FUTURE...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
