Ready to Buy a 790?
   / Ready to Buy a 790? #1
EastTNBrooke
Rockford TN - Foothills of the Smokies
JD 790 MFWD
I just bought 2.3 acreas of pasture with half having a side slope of 15 - 19.25 degrees. I have a 1000 feet of gravel driveway and have just started a new house on the site. I plan to purchase a JD790 with a FEL, Box Blade, & 60" RFM. Will the non syncro gearbox be to much of a problem with the FEL or will being in hi-range and shifting between 1st & reverse work fine on level ground. I have also considered the MF1528 & the Kubota L3400. Due to right leg trouble, I want to avoid HST's. Is the 790 the right machine?
I once had 2 ac of flat land and JD650 with a RFM and I loved it!
   / Ready to Buy a 790? #2
You will be fine. Just make sure to mow up and down the slope. My setup is similar to yours except I have the rotary mower instead. Doing FEL work you will be constantly shifting between reverse and 1st gear. This shift is a straight line back and forth in the pattern.
   / Ready to Buy a 790? #3
If your drive has an incline you will want 4X4 for sure. My 2WD 790 was useless trying to pull a boxblade up a slight slope, even with the differential locked. My 790 if about perfect for finish mowing to me.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
NAPA 230V AIR COMPRESSOR (A53843)
NAPA 230V AIR...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2019 Ford Econoline Ambulance (A51692)
2019 Ford...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
