Ready to but woodsplitter; a few questions
   / Ready to but woodsplitter; a few questions #1
Highridge
Southeast, MA
Power-Trac 1430 and Craftsman DGT6000
I just cut down a bunch of trees and want to split them and get them stacked this spring. I've attached a link to the Northern Tools 3-point splitter. I'm gonna get the $150 quick attach plate and weld it on.
I'm planning on using the PTO to power it. With a log-splitter valve, does the oil continuously flow throw it?
Thanks
Northern Tools
   / Ready to but woodsplitter; a few questions #2
The log-splitter valve has what you call an open center and fluid passes freely through it when the valve is in the center position. The valve will also be preset at a psi some where between 2000 and 3000 PSI. This will let the system build up no more than that much pressure when splitting a log. When you pull the valve into the reverse position and let go of the handle the valve will stay in and keep bringing the cylinder back until it is all the way. When the cylinder is all the way in and the system reaches about 500 psi the valve will kick back to center on its own.
   / Ready to but woodsplitter; a few questions #3
I thought about buying that splitter too. I was going to weld a 2" square tube to it and remove the 3pt hitch assembly. I would mount it to a receiver plate that I welded up in class.
This would also allow me to rotate the splitter 180 degrees to pick up logs and split them.
I finished the mounting plate, but have not taken the second class yet. That will come over the next two months.
   / Ready to but woodsplitter; a few questions #4
Here's what I was thinking of doing with the Northern splitter, or one that I would build myself.
   / Ready to but woodsplitter; a few questions #5
You may want to put a foot on it to relieve some pressure and as a safegaurd for when you are not sitting on the tractor when using the splitter in the "traditional" position. Never know when someone will bump the joystick and drop it on someone's foot. /forums/images/graemlins/shocked.gif
   / Ready to but woodsplitter; a few questions #6
I think the foot/support would be a good safety precaution/forums/images/graemlins/cool.gif, but with my luck I would have my foot under the splitter foot when someone hit the joystick. /forums/images/graemlins/frown.gif
   / Ready to but woodsplitter; a few questions #7
Actually, that's a pretty good idea. The foot could be on a pivot and able to swing 180 degrees and lock. This way if the splitter is upright or upside down, it can still act as a support. It could also be removable for those times when you are only working from the tractor and are picking up logs to split.
   / Ready to but woodsplitter; a few questions #8
I have used one of these 3pt splitters for several years now. I really like the stand design that takes all the weight off the tractor.
That's a nice idea!
It would work great. How hard was it to fab that up?
   / Ready to but woodsplitter; a few questions #10
Really not hard at all, did it an a few hours. My intent was to have something that would work with attachment slike the wood splitter.
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A51572)
2013 Dodge Charger...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
1993 International 4900 Flat Dump Truck, VIN # 1HTSDPNM9PH489370 (A51572)
1993 International...
