re-using washers and bolts on mulcher teeth
   / re-using washers and bolts on mulcher teeth #1
t320pilot
NW Fla
Kubota KX 057-5 excavator , Ford 2600 tractor , Bobcat T320 with Fecon mulcher (sold), Kubota L2501DT 4x4
When rotating or replacing teeth do you buy all new bolts and washers or re-use them?
   / re-using washers and bolts on mulcher teeth #2
On the Fecon similar to the HDT style teeth I replace the bolts. The reason being is that when I tighten them the bolts stretch and will not stay tight the second time around.
   / re-using washers and bolts on mulcher teeth #3
On any machine I always replace the nuts and normally the bolts also. I would rather pay a little for bolts and nuts than to have repair something that broke or came loose while using it.
   / re-using washers and bolts on mulcher teeth #4
I reuse them for my Fecons with paddle style drums. When the threads on the bolts and the nuts get beat up then I replace them. I have never had a problem with loosening or breaking in 10 years.
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52128)
2016 Kawasaki 70...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
71065 (A49346)
71065 (A49346)
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
