re-using washers and bolts on mulcher teeth
   / re-using washers and bolts on mulcher teeth #1
t320pilot
NW Fla
Kubota KX 057-5 excavator , Ford 2600 tractor , Bobcat T320 with Fecon mulcher (sold), Kubota L2501DT 4x4
When rotating or replacing teeth do you buy all new bolts and washers or re-use them?
   / re-using washers and bolts on mulcher teeth #2
On the Fecon similar to the HDT style teeth I replace the bolts. The reason being is that when I tighten them the bolts stretch and will not stay tight the second time around.
   / re-using washers and bolts on mulcher teeth #3
On any machine I always replace the nuts and normally the bolts also. I would rather pay a little for bolts and nuts than to have repair something that broke or came loose while using it.
   / re-using washers and bolts on mulcher teeth #4
I reuse them for my Fecons with paddle style drums. When the threads on the bolts and the nuts get beat up then I replace them. I have never had a problem with loosening or breaking in 10 years.
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
