Oil & Fuel Re glow plug life
   / Re glow plug life #1
fordman6442
Terrace B.C. Canada
67 massey 165,1947 Farmall A, 1949 Massey Harris, 1955 Ford 600 with b/hoe and loader J.D. 350 Crawler with winch and 6 way blade,Kabota riding mower, Husquavarna riding mower,Kawasaki quad and a wife
I have a Kubota B2320 with 264 hours on it. Is it common for this unit to have glow plug failure. When I start it now it fires on one cylinder for 10-20 seconds then picks up and starts on the other 2. I haven,t called my dealer as it is Sat night. Any input??
   / Re glow plug life #2
Glow plug testing is a simple matter. I have had no problems with the BX2200 but I have had with my VW diesels.
First remove the glow plugs. Then you can use a jumper cable and clamp one end on the - batt post and hold the body of the glow plug in the other end,you can touch the top of the plug to the + batt.,post and see if it lights up. A good glow plug will turn red fairly quickly.
Plug life seems to be hit and miss.
Dan
   / Re glow plug life #3
Or - you can use an Ohm meter to test the resistance across the plug. I would have to check the shop manual to see what the resistance is supposed to be. However, if you have an open circuit, then that's a clear sign that the glow plug is bad.
   / Re glow plug life #4
How many cyl. is your tractor?
   / Re glow plug life #5
Rare, but first time for everything!
   / Re glow plug life #6
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
Tesco 200 Gallon Tank (A50774)
Tesco 200 Gallon...
66" Skidloader Tooth Bucket (A50774)
66" Skidloader...
(INOP) 2003 HAULOTTE OPTIMUM 1930E SCISSOR LIFT (A51243)
(INOP) 2003...
Spool 19mm Wire Rope (A47384)
Spool 19mm Wire...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
