Re-decking trailer
/ Re-decking trailer #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
It's time to redeck my 8 year old equipment trailer. What would work best? 2x6, 2x8, 2x10? It seems like a wider board might split easier. Factory is 2x6.
/ Re-decking trailer #2
Use what came on it.
Do you know the board bowing trick? I redeck 4 or so trailers a year a year and can do one in under a hour. It takes some people 2 days.
Chris
/ Re-decking trailer #4
Well if its 2x6 now then the fractional dimensions would have to be the same at the end obviously if you use something else. I use a combo of all of those on my car trailer and yes the wider boards will split easier/warp worse least they do for me. Does the trailer have angle iron welded at the ends of the boards to hold them? (that's what Chris is talking about)
/ Re-decking trailer #5
2x6 would be easier if some have lateral bows in them. If the boards are not full length stagger the joints.
Uh, I'm in the group that take a few days to install a deck but I bolt at each crossmember and add an extra layer a foot wide on each wheel track.:D
Will you be using self tapping screws or ordinary bolts?
My trailer has the boards captured by a welded bar at each end. Chris, can you give me a brief description of your system?
/ Re-decking trailer #7
Is the board bowing trick, where you bow a full length board in the middle, so it'll be short enough to fit under the captures at the ends?
/ Re-decking trailer #8
First off look under the trailer and look for wiring, ect. Take your chain saw and run it from side to side between cross members to remove old boards. I usually cut between the back and last support because there is less wiring, ect.
Next cut new boards to length. Now you can put in about 60% of the new boards by cocking them in sideways and beating them in place with a sledge hammer. You want them tight because they will shrink.
The last few boards you will need a helper and about a 16" piece of scrap 2X4. Place the front end of the deck board on the "cup" and place your scrap piece of 2X4 vertically on the back axle. Now have your helper, preferably a fat buddy stand on the back of the board bowing it by the rear cup. Take your sledge hammer and knock out the vertical piece of 2X4 and it will snap into place.
You may have to use the front axle or adjust the length of the 2X4 for your particular trailer.
I do them from time to time using my FEL bucket to apply the down pressure in place of a fat buddy.
Hope this helps.
Chris
/ Re-decking trailer #9
I've always heard of that method used on 14-16 foot or longer trailers. I wonder if it would work on a 6-8 foot trailer using 2x6's.
Anyone tried it with a short trailer?
Bruce
/ Re-decking trailer #10
That sounds great for the bed boards, but how do you get the last board in on a sloped tail section...they're so darn short.
/ Re-decking trailer #11
Hope this helps.
Chris
Chris, what's your preference for species of lumber? And you are using rough cut (full thickness, not dressed) lumber correct?
In another thread I asked if anyone had substituted steel planks such as GripStrut for wood. I don't remember what the response was or if you even saw the thread but have you ever considered this?
/ Re-decking trailer #12
99% of the time I am using treated lumber from Menards or Lowes. I have also used real 2" planks of White Oak from the local saw mill but only on a 25,000# GVWR tag trailer.
Most your 14,000# and under came with and are just fine with treated 1.5" thick stuff.
Chris
/ Re-decking trailer #13
I think you are talking about a dove tail? Usually 2' to 5' long. In all honesty in the 25 or so I have done only 1 was a DT.
What I did was on the far right side I cut out a piece of the top of the angle iron one board in. I belive it was 2X8 boards so I cut out the angle iron 8" wide. I did this where the top of the DT meets the flat trailer deck using a thin cut off wheel in my angle grinder. I then measured out 1" from each side of the cut and drilled and tapped the trailers angle iron to accept 3/8" bolts. I then got a 2" wide piece of 3/16" flat stock and cut off a piece about 12" long and drilled it to make a "cap".
You then drop in all the boards one at a time and slide them into position using a hammer to persuade them. The last board drops in then the cap is bolted into place. I used 3/4" long bolts with a flat washer and lock washer.
Chris
/ Re-decking trailer #14
my dove is semi open self celaning metal slats. after hearing about the short wood repalcement. i'm glad it is.
/ Re-decking trailer #15
As Chris said, 1 1/2 in thick is adequate for many applications. I personaly let the trailer dictate how thick the replacement decking is. I like my deck boards flush with the top of the trailer frame, so if the top of the cross members is 2 in below the top of the frame rail, I install 2in thick boards, if it is 1 3/4, thats what I have the mill cut. As for species, If you are going to be hauling a machine with steel tracks on any type of regular basis, GO WITH HARD WOOD OAK, regardless of thickness. The steel tracks will shred pine decks in no time. On my personal trailers, 99% of what goes up there is rubber tired, so I get great service life out of pressure treated pine, it is half the cost of oak, lighter weight, and easy to find in my area. The local mill always has a good supply of treated pine logs ready to saw.. Typicaly the pine last me a minimum of 7 years.
/ Re-decking trailer #16
I've re-decked many dozens of 40', 45' and 48' semi trailers. Even steel decked a 48' Landall.
Normally it took 20-30 man hours to remove the old and install the new screwing the boards down with torque head 5/16" floor screws.
That's busting the old floor out with a 12lb sledge hammer, busting off the old screws too.
I still have a homemade "T" drill handle that fits a CP air drill so I could stand up and drill the holes!
It takes the better part of a 50lb box of screws to do one.
I always run a couple rows of floor screws on the smaller trailers. It keeps the boards from warping and makes the trailer a lot stronger.
I never liked the drop in floor boards. They are fast to build but lack strength.
/ Re-decking trailer #17
I use a chainsaw to tear down also and wrenching the boards up usually breaks the deck screws across the stringers. I haven't done a whole lot of trailers mostly mine every so often.
I find the deck screws must be hardened and are pretty brittle if any are left sticking up a hammer blow from the side breaks them flush usually and a 4" fixes the stragglers then I just drill new holes and screw new screws in.
/ Re-decking trailer #18
If you are towing all "wheeled" vehicles I'd use PT 2x6 or 2x8: whatever is your cheapest square footage for the job. Ditto on knocking off the heads: you'll waste a lot of time attempting to extract them, and never line up the holes on the few you manage to remove. You will spend more money and time on self-tapping hardened fasteners for narrower wood, so factor that into your cost. Also, I needed to go to a trailer dealer to find them. They don't self tap well & you'll be ahead pre-drilling a good pilot hole rather than trying to let them knaw their way into angle iron.
I did my 20 footer & 2x8 was the best price and original used, but it did take a 2x6 at the end to finish... My deck has two 90 plates capping the beavertail & deck end, so I didn't have to deals with bowing or squeezing, except that last 2x6 went a little tight. I brushed it down with motor oil after it weathered a bit, which was likely a completely unnecessary waste of time and slid around for the first year, but now it's fine & I feel better for it now that I can stand up on it!
While you have the deck off: that's the time to rewire, sand prime & paint & check everything you can't usually see easily, so don't get too rushed with it; take time to do the whole 9 yards while you have an easy work area.
I made cold frames with the old decking--will give you some material to make a non load bearing project.
Good luck--it's an easy project and will give you years of piece of mind if you cover all your bases while you have it ripped up.
/ Re-decking trailer #19
Lowes carries the self tapping deck screws.
Chris
/ Re-decking trailer #20
So does Menards. But they don't call them trailer decking screws, just self-tapping. I bet HD has the same thing. I still pre-drilled when I had to replace a deck board as I didn't trust the screws to actually drill the hole themselves. Not hard to do and worked well.
These were the ones I got:
Teks #12 X 2-3/4" Plymetal 40Ct at Menards
