Re-Decking a Trailer
   / Re-Decking a Trailer #11
There is no need for PT wood on a trailer deck. If I were replacing a deck today I would use Oak planks and give them a couple of coats of a good UV sealant. Then, after installation, I would undercoat with a rubberized automotive undercoating.
Clean and recoat the deck surface with a UV sealant every couple of years and the new deck should outlast you.
   / Re-Decking a Trailer #12
Painting, If it remained completely intact would be a good option. However, a scratch or chip of the paint's surface provides an entryway for the moisture, especially on a horizontal surface such as a trailer deck, and instead of keeping water out, the paint traps it inside the wood, accelerating decay.
Jeff
It's not rotting yet, but it will need painted this year if not replaced.
   / Re-Decking a Trailer #14
</font><font color="blue" class="small">( I've found buying green oak cheaper and stronger than the pine lumber at the box stores.
And I don't see the advantages of treated except for ground contact.
Check around. There might be a mill that cranks out oak planks for pallets etc. You'll find it cheaper than pine finished lumber. )</font>
Harv - Do you know of a mill in our area that has the green oak? My trailer needs a new floor and it's only 5 years old. I painted it (top only) when I bought it, but it stays parked beneath the trees and I have a bad habit of ignoring it when I don't need it.
Steve
SKID STEER ATTACHMENT BRUSH WITH BOX (A58216)
SKID STEER...
Gorman Rupp 14D52 10 Series Centrifugal S/A Towable Water Pump (A56857)
Gorman Rupp 14D52...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
38" X 53" X 16" FUEL TANK (A58374)
38" X 53" X 16"...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
