RDrancher's Photo Thread
/ RDrancher's Photo Thread
You're gonna love the gannon- and you even got the scarifiers to!! I ended up with this one because a couple guys that the seller showed it to complained about it, because their cut's couldn't pick it up!! So he offered it for $250, Which i jumped at, but somebody cut out the hydraulics and no scarifiers. Still , think it was the best bargain of all of the used implements. Enjoy the box blade
Thanks! I don't think I'll be hooking my ratchet rake tooth under the top link pin to load this beast on the trailer. That tooth is already bent a bit from the 660lb Bush Hog. :D
/ RDrancher's Photo Thread #302
I need to call AG-Power in Rhome tomorrow. I think they're the closest Woods dealer for parts. If they have to order them I may just call Messicks and have them shipped. I'll be working in Blue Ridge all next week (at the other end of the earth.) :laughing:
John, from Sanger, I think Ag Power in Gainesville is closer. It's on Hwy 82 just west of I-35. I've never been in that store, but I've been past it a gazillion times. They are a bit smaller than Ag-Power in Rhome, but they are still a very big dealership.
EDIT: Oops!!! That is not Ag-Power in Gainesville. It's Pettit Machinery. Here's their contact info:
1710 Hwy 82 West
Gainesville, TX 76240
phone: 940.668.6042
fax: 940.668.7504
Thanks Jim. Landmark Equipment and Sunstate Rentals in Mckinney and Sunbelt Rentals in Denton are also listed as dealers. I'll give them all a call and see if anyone just happens to have the parts I need.
Looking at my old Bush Hog, I think I'm going to cut off the box and make it into a ripper-only attachment. The blades on the BB haven't been flipped yet and I wanted to get "reverse" blades mounted on my Landpride landplane anyway to protect the angle iron and spread in reverse. They'll probably last forever on the landplane.
The beautiful side..... just sayin..... ;)
And really wet! :D
Here's a few photos from the bog today.
My Father-in-law is here for the summer to expand the brush hogging end of my business, so I had him come out today to mow and help define the driveway.
/ RDrancher's Photo Thread #309
Did you pinch him or did he live ? Doesn't look like a rattle , maybe it is .
Its a rat snake. I punched a hole in him while I was digging out the bog, so I put him out of his misery.
I wanted to let the bog dry out for a day, so I stripped the driveway with the power rake. Neither solenoid would work for the angle function, so I took off one of the side plates to help move material to the center. It took a bit longer than usual. Hmmm...looks like I smeared my camera lens with something or other.
My FIL was 70 miles away from my job mowing 14 acres.
/ RDrancher's Photo Thread #312
When you strip with the PR do you windrow and pick it up ? And those solenoids never worked either for us . The most useful feature , and it never worked . Great looking outfit you have , family , machinery , and customers .
Thank you Kevin. I took the left side end plate off the rake since it kinda naturally moves material that way, so I was able to windrow the grass and then pickup with the bucket. As far as I'm concerned the power rake is the most amazing attachment ever invented. Strip, rake, grade and make things look pretty too...amazing.
Don't even try to walk on this bowl of jello. I don't know where the bottom is, but I was in over the tracks several times.
Graded out the exit end of the crossing, eliminated a couple of drainage berms and then spent an hour or so trying to clean the machine.
I just noticed in the culvert exit pic that you can still see brownish dirt from the rusty tractor axles and parts that I dug out.
/ RDrancher's Photo Thread #315
I see your clients have plenty of the "Texas Broadleaf Grass" in their pasture.:laughing:
/ RDrancher's Photo Thread #317
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=313675"/>
You haven't seen the worst of it! The Noble Foundation said if we start treating it now we might kill it off in a couple of years! Any recommendations are welcome!
/ RDrancher's Photo Thread #318
I think your best bet is to grub it up by the roots, pile it up, and burn it. I've seen some places between Decatur and Fort Worth that are almost solid pricklypear. I have it on my place, but not a lot, probably less than 20 plants on 22 acres. I have a burner that you attach to a propane tank and I think I'll give that a try this summer with my grandson. He loves anything that goes bang, explodes, or burns. Cooking the cactii should be a great job for him.:D
Grub it and burn it, burn it in place and then grub the roots, or spray it with Tordon or Remedy and diesel. The end result is the same...its a two to three year battle, sometimes even more. Any little pieces left over will start a new plant, so it pays to be thorough when cleaning it up. Don't bother trying to use gloves (even welding gloves) for pickup. Just pull up to it with the loader bucket and rake it in with a garden rake.
I pulled off the jello bowl job last week with rain on the horizon. I figured it wasn't worth it to try to grade material that was pumping, even in the "dry" areas.
Then I did what I always do when I get antsy...I start another job. In this case...two "easy as pie" one-day, Saturday jobs. Both of them bit me in the hind quarters. Well actually, just one, but the other became quite a bit more involved.
I sent my father-in-law out with his L4240 to fill some depressions left from another contractors leach field install. It should have been an easy ten yard topsoil spread. About an hour later I get a call from him..."I'm buried up to my axles!" He had broken through the hard top layer of clay and found the jello below. He got out, but made quite a mess doing it. Not his fault...Texas clay can have a pretty steep learning curve! So I told him to head on home.
Meanwhile, I'm on a drainage re-grade next to a daylight garage. I knew that the job would also entail a bit of leaking wall investigation, but I never expected to find a 2x6 right in the middle of a concrete stem wall, hidden behind stone veneer and extending 36" below grade. Hmmm, I wonder why it leaks? :rolleyes: After I removed some drywall in the garage, I found that not only had the contractor left a header form in the middle of the wall and covered up his mistake with stone. He also used the other side of the form as a stud to attach the drywall...jeez. I could see daylight next to the "stud" from the inside. The exposed "custom stud" is also full of termites. That made for a screeching halt to my part of the job for the time being. The new owner is also dealing with mold remediation on the other side of the house. The home was purchased in foreclosure from the previous owner...a local architect and builder. Double jeez!
So Saturday was not very productive for either one of the jobs and since the topsoil on the first job was blocking the customer's culvert, I decided I'd better try to make it work before the rain hit...that didn't.
Here's the result of a buried L4240...after he fixed it. :D
Here I am making smooth lumpy stuff out of bumpy lumpy stuff. A lot of work for a little topsoil. I'll go back and make it nice after the ground dries up.
Here's the custom concrete / wood stem wall with the builder's version of waterproofing.
Every once in awhile I get a request from a customer to do a little out of the ordinary repair. This customer had paid two handy men to replace this water damaged siding and never saw either one of them again. With no contractors licenses required around here to maintain accountability and a level playing field, it's really a free for all. My FIL stripped off the damaged material and found that the sheeting had only been corner nailed. :rolleyes: After securing the sheeting with screws along the edges and in the field, he put in a trim board as a break between the old and new siding, then caulked and painted the entire backside of the shop. Since the company that originally manufactured this particular siding has been out of business since 2007, he chose a suitable replacement. I think that it turned out nicely.
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2025 Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
2009 CATERPILLAR D6K XL CRAWLER DOZER (A64279)
2009 CATERPILLAR...
