Mowing RCK60B-22BX deck belt
/ RCK60B-22BX deck belt #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
Question for everyone. When do you know that your belt needs replacing? I replaced the belt tensioner arm and put new blades on. The deck is still vibrating a bit and the other pulleys are all good. Could a bad belt cause the deck to shake a bit? It's like I have something out of balance but can't for the life of me figure out what it could be.
matt
/ RCK60B-22BX deck belt #2
Remove the blades and see if the vibration disappears.
If the vibration is gone then replace the blades one at a time to identify which one is causing the problem.
A bent blade will vibrate.
A belt that has slipped and thus developed a flat spot will vibrate like a tire with a flat spot
Dave M7040
UNUSED FUTURE FT-GB200-79"X71 1/2"-1" STEEL PLATE (A60432)
UNUSED FUTURE...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
