Mowing RCK60B-22BX deck belt
   / RCK60B-22BX deck belt #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
Question for everyone. When do you know that your belt needs replacing? I replaced the belt tensioner arm and put new blades on. The deck is still vibrating a bit and the other pulleys are all good. Could a bad belt cause the deck to shake a bit? It's like I have something out of balance but can't for the life of me figure out what it could be.
matt
   / RCK60B-22BX deck belt #2
Remove the blades and see if the vibration disappears.
If the vibration is gone then replace the blades one at a time to identify which one is causing the problem.
A bent blade will vibrate.
A belt that has slipped and thus developed a flat spot will vibrate like a tire with a flat spot
Dave M7040
   / RCK60B-22BX deck belt #3
You can check bent blades by using a screw driver or nail. Take the blade off, and see if it balances.
How to Balance Mower Blades : Lawnmower Maintenance & Repair - YouTube
Again, there are a truckload of other videos on Youtube if you don't like this one.
If they all look OK, then proceed to check to make sure they are centered on the spindles.
2022 Bobcat S770 Skidloader (RIDE AND DRIVE) (A50774)
2022 Bobcat S770...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2020 Gehl RT105 Skidloader (RIDE AND DRIVE) (A50774)
2020 Gehl RT105...
2012 RAM 5500 (A52472)
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
