rck60b-22bx bearings
   / rck60b-22bx bearings #1
MikeLad61
Orange County, NY
Kubota BX-22
After reading an old post on bearing failure on a rck60-24b I decided to check my mmm as I wanted to switch over to a synthetic grease. One of the bearings spun roughly so I changed all of them. When I pressed the new bearings in I found resistance for about 3/4 of an inch and then the bearing was able to be pushed in by hand. I noticed that the outer ring of the bearing can slip if forced lightly. The old bearings are not burnt and the housing has no sign of wear or damage. I would like to know if slippage of the outer ring is normal for these bearings. In a car the outer ring doesn't move. Thanks for the help.
   / rck60b-22bx bearings #2
Hello…
That type of problem occurs anytime the tolerance of a bore and the tolerance of a shaft or cylinder are at their extremes… The outer or inner race should be caged firmly to prevent movement or tipping.
Loctite and others make a ‘bearing race mount’ adhesive that will work… in the case of a ‘spun’ bearing race … Loctite has a filler for shafts, that will work well even with extreme wear. I used this on a final drive on a cat motor grader… I was planning to use it as a temporary fix, but it worked so well I left it permanent.
Secure all bearing races, check with your bearing supplier for mounting products. If you use the correct stuff you will have no problems in future disassembly. KennyV.
2016 FREIGHTLINER M2 WATER TRUCK (A51247)
2016 FREIGHTLINER...
UNUSED TOPCAT ECSSSTG200 HYD STUMP GRINDER (A51248)
UNUSED TOPCAT...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2018 Genie GTH-636 (A50123)
2018 Genie GTH-636...
